Suspension & Brakes Theory, alignment, spring rates....
Function7 subframe asr rear sway bar with brackets
Old 09-05-2016, 07:48 PM
mugenNR10's Avatar
Default Function7 subframe asr rear sway bar with brackets
I've searched with no prevail. Read a thread that function7 said it is possible. Want to see if anyone has any pics before I buy the asr rear sway bar. The 25 mm with d brackets. Would like to avoid using energy suspension. Thanks.
Old 09-05-2016, 08:33 PM
On vacation
testify's Avatar
Default Re: Function7 subframe asr rear sway bar with brackets
I think you me "I've searched to no avail".
It's a swaybar, they are all the same. If the brackets will bolt to a stock subframe they will bolt to the ASR brace as it uses the same mounting locations.
Old 09-05-2016, 09:35 PM
mugenNR10's Avatar
Thanks for the correction. They don't. The stock doesn't fit the function 7.
Old 09-06-2016, 08:32 AM
Andy@AMR's Avatar
I am a Function 7 distributor, I have plenty of clients including myself who have used the ASR on the Function 7 brace. What seems to be the issue?
You need a swaybar, I got a 24mm that will work, with brackets.
Old 09-06-2016, 09:59 AM
Master Detailer
98civdx's Avatar
Are you using the smaller D brackets from an EM1/DC? (NON ITR)
If so, that's your issue.
Mikes2000civicsi
03-27-2008 09:02 PM
JunY
34
02-09-2006 04:43 PM
MaaseyRacer
08-17-2004 09:40 PM
cxSOHChatch
08-19-2002 05:31 PM
Petah
05-17-2001 05:36 PM
Quick Reply: Function7 subframe asr rear sway bar with brackets
