Suspension & Brakes Theory, alignment, spring rates....
front toe adjustment
Old Nov 29, 2007 | 07:18 PM
brototoy's Avatar
Default front toe adjustment
can this be done on an ek sedan?
Old Nov 29, 2007 | 07:20 PM
supracrx's Avatar
all cars have front toe adjustment....
on most hondas without replacing some parts, its camber and caster that are not usually adjustable...but toe is always adjustable
Old Nov 29, 2007 | 07:23 PM
brototoy's Avatar
Default Re: (supracrx)
ok thanks, how can the front tow be adjusted?
Old Nov 29, 2007 | 07:24 PM
supracrx's Avatar
front toe u mean right?
on the tie rod ends there is a nut u loosen and u adjsut it BUT u have to have the alignment machine..
Old Nov 29, 2007 | 07:37 PM
brototoy's Avatar
ok thanks! how about front caster? my front right has more + caster than the left. does having an unequal height (driver side lower than passenger side) have anything to do with this?
Old Nov 29, 2007 | 07:56 PM
brototoy's Avatar
Default caster
how can front caster be adjusted?
Old Nov 29, 2007 | 08:33 PM
Targa250R's Avatar
be professional
Default Re: (brototoy)
I merged your two threads on alignment topics.
Caster is not adjustable on a '96-00 Civic. Only toe. Slightly uneven caster won't matter, but grossly uneven caster may cause the car to pull to either side and possibly indicates frame or control arm damage.
Uneven ride height left-to-right is normal for most Hondas using lowering springs.
Old Nov 30, 2007 | 03:03 PM
brototoy's Avatar
Default Re: (Targa250R)
frame meaning subframe? or the chassis?
Old Dec 2, 2007 | 10:01 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brototoy &raquo;</TD></TR><TR><TD CLASS="quote">frame meaning subframe? or the chassis?</TD></TR></TABLE>
Either/or.
Old Dec 8, 2007 | 08:34 AM
CTR01's Avatar
Certain vehicle manufacters uses different casters to counter road crown.
civicguy66
Nov 18, 2018 01:30 PM
nealnanoHX
17
Jun 5, 2013 05:13 AM
95ejjj
Suspension & Brakes
May 21, 2010 09:46 AM
VtecnTurbo
Suspension & Brakes
24
Dec 28, 2007 03:32 PM
ACRXGuy
Jul 1, 2003 07:55 PM
