*wheel stud replacement*
I have some broken studs on a set of integra knuckes that ill probably end up selling, so I need to fix them. They're off the car, with the rotor removed. All the DIY that I've found use an axel puller, is there anyway to replace the studs without one?
yeah i always shave about 1/4" off the knuckle and then grind one side of the stud head flat to give more clearance. then just pull it through with a few washers and a lug nut.
yh23
Suspension & Brakes
06-02-2005 10:10 PM
