ef9 brake conversion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fatboys_ef9 »</TD></TR><TR><TD CLASS="quote">can i use any integra brakes to do a conversion on a 91 civic hatchback</TD></TR></TABLE>
FRONTS using 10.3" front rotors:
90-93 integra knuckles & calipers
90-91 civic ex 4dr knuckles (rare & expensive)
the 10.3" front brake conversion requires a bigger master cylinder (from a 90-91 civic ex 4dr, bolts onto your booster) to push more fluid to the bigger pistons.
https://honda-tech.com/zero...age=1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fatboys_ef9 »</TD></TR><TR><TD CLASS="quote"> from drum to disc what parts do i need? </TD></TR></TABLE>
REAR:
any 90-01 integra or civic with rear disc will work, you'll need disc brake hoses since the drum ones won't work. 90-93 integra & 96-00 civic rear lca's are not compatible with your 91 civic hatch, you can keep yours or use any ef, eg or dc rear lca's.
* use 90-93 integra or 90-91 crx/ ef civic si e-brake cables
https://honda-tech.com/zerothread/1916212
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fatboys_ef9 »</TD></TR><TR><TD CLASS="quote">let me know whats up
https://honda-tech.com/zerothread/1811368
REAR:
</TD></TR></TABLE>https://honda-tech.com/zerothread/1811368
racingant
19
May 3, 2005 07:19 AM
Parn_36
Mar 29, 2005 12:42 PM
h22civic95coupe
May 7, 2003 08:03 AM
