Negative Tire Setback....Problems?
Old Oct 17, 2003 | 01:39 PM
MrIllegalX's Avatar
Default Negative Tire Setback....Problems?
My passanger side tire has a .54" setback due to hitting a curb.
The setback is caused by the frame being offline. I can't pull the frame anymore than it's already been pulled.
Has anyone else had a setback, and is there a way to make it any better?
And also, is there a reason that my camber on my right side is less than my left?
Here's my info from a 4-wheel alignment awhile back.
Old Oct 17, 2003 | 02:43 PM
pro1342's Avatar
The specs indicate your car will pull to the right. You might need a knuckle or LCA......
Old Oct 18, 2003 | 09:23 AM
MrIllegalX's Avatar
LCA was replaced. knuckle could be a possibilty.
Car does pull to the right, but after the 4-wheel alignment it's not as bad as it used to be. Pulling isn't my major concern. It's how many turns it takes to go left v. how many turns it takes to go right.
Old Oct 18, 2003 | 11:45 AM
pro1342's Avatar
The rear beam/crossmember could be bent, too.
VTECROAR96typeR
Suspension & Brakes
Apr 4, 2010 10:11 AM
yOnKiNaToR
Oct 16, 2008 06:39 PM
agiorlando
Sep 14, 2008 04:44 PM
EGBuddy
Apr 22, 2006 11:19 AM
rody084
Apr 16, 2003 01:30 PM
