Suspension & Brakes Theory, alignment, spring rates....
Allignment Question...
Old Jan 8, 2005 | 01:21 PM
  #26
.RJ's Avatar
.RJ
Default Re: (Nate047)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nate047 &raquo;</TD></TR><TR><TD CLASS="quote">I burned through tires like ******* blunts or something... </TD></TR></TABLE>
Then your toe wasnt correct. Simple as that.
Old Jun 27, 2005 | 04:58 PM
  #27
EGTURBO_again's Avatar
Default Re: (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Then your toe wasnt correct. Simple as that.</TD></TR></TABLE>
he was his toe was perfect.
sorry to bring back this thread but seems like a good one to bring back up..
my situation is this
i have ingalls camber kit installed in my eg hatch. have been adjusted and aligned at least three times the past 6 months or so. and my tires still wear out like crazy..
the right side will wear out fast. but the weird thing is that it wears out evenly throughout the whole tire. and my left side will wear out fast but from the mid to inner section..
can anyone help me? im tired of always having to worry about my tires when i drive to like l a or something or like an hour drive etc. plz help.
Old Jun 27, 2005 | 09:30 PM
  #28
Default Re: Allignment Question... (Nate047)
Old Jun 28, 2005 | 11:30 AM
  #29
Default Re: Allignment Question... (EGTURBO_again)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGTURBO_again &raquo;</TD></TR><TR><TD CLASS="quote">???</TD></TR></TABLE>
Old Jun 28, 2005 | 08:48 PM
  #30
XxDJCyberLoverxX's Avatar
If you gotta get an alignment every time u alter the ride height, I don't see too much point in gettin' adjustable coils like Tein or something unless you're tracking a lot, but like.. i gotta question...
If you raise/lower the suspension for like a track day, and then afterwards put it back to the position you had it before, do you still need to get it aligned?
Old Jun 29, 2005 | 11:45 AM
  #31
DBOT's Avatar
Default Re: Allignment Question... (XxDJCyberLoverxX)
if you change your height even the slightest, is it like a dramatic change in your alignment or is it just an over time kinda of thing. whats the worst case scenario?
Modified by fourstar at 4:41 PM 7/1/2005
Old Jun 30, 2005 | 01:37 PM
  #32
heel_touge's Avatar
Default Re: (EGTURBO_again)
can anyone help me? im tired of always having to worry about my tires when i drive to like l a or something or like an hour drive etc. plz help.</TD></TR></TABLE>
perfect meaning what? every car has a certain toe angle spec which on most if not all hondas is not 0.
if you want minimal wear, set the toe angle to 0 degrees. you also have the benefit of better turn in etc.
are your tires properly inflated?(this seems to be the most logical answer to your irregular wear problem)
has your car ever been wrecked?
thrust angles can also cause wear can they not? (correct me here if necessary)
Old Jul 4, 2005 | 05:49 AM
  #33
PupaScoopa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XxDJCyberLoverxX &raquo;</TD></TR><TR><TD CLASS="quote">If you gotta get an alignment every time u alter the ride height, I don't see too much point in gettin' adjustable coils like Tein or something unless you're tracking a lot, but like.. i gotta question...
If you raise/lower the suspension for like a track day, and then afterwards put it back to the position you had it before, do you still need to get it aligned? </TD></TR></TABLE>
If you return it to the same specs as before, you won't need to realign. If you do this often, your original spec will "drift" away from where it should be.
It's not too hard to measure toe every now and then. Just use the masking tape and measuring tape trick.
98BabiGs-T
Suspension & Brakes
Mar 23, 2007 10:44 AM
xgxchicken
Mar 1, 2005 03:58 AM
papa5murf
Honda S2000
May 21, 2004 10:39 AM
nijia555
Oct 27, 2002 03:59 AM
Volcom
Mar 3, 2002 07:10 PM
