97 civic no abs braking bleeding sequence
ok so i was always taught start with the furthest wheel then work my way to closest to the master cylinder.... but then i check honda service manual and this is what i got ..
http://htmlimg1.scribdassets.com/5ax...2a18f3d933.jpg WTH ... can anyone explain why after passenger rear ... followed by driver front ? could it be a typo ? |
Re: 97 civic no abs braking bleeding sequence
nope
not a typo brah, thats how you need to do it. this process is best performed with a friend pump the brakes |
so this doesnt fall under the " furthest from master cylinder" rule... because the master cylinder is right next to the driver front brake... this is so wierd
1 Attachment(s)
Attachment 526894
the prop valve does not mix together channel A and B there are two channels going from master cylinder to proportioning valve lets call them channel A and channel B channel A will split off to front left and rear right channel B will split off to front right and rear left when purging/bleeding the hydraulic brake system you must do each channel separately when starting on a channel you must do the rear first the master cylinder is on the same side as the driver's seat (obviously, right?) start with the diagonal rear brake bleeding/purging order: driver's seat on left RR, FL, RL, FR driver's seat on right RL, FR, RR, FL refer to this thread https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/proportioning-valve-channels-3194933/ |
Originally Posted by properlystewed
(Post 49533422)
https://i.imgur.com/tP9I940.png
the prop valve does not mix together channel A and B there are two channels going from master cylinder to proportioning valve lets call them channel A and channel B channel A will split off to front left and rear right channel B will split off to front right and rear left when purging/bleeding the hydraulic brake system you must do each channel separately when starting on a channel you must do the rear first the master cylinder is on the same side as the driver's seat (obviously, right?) start with the diagonal rear brake bleeding/purging order: driver's seat on left RR, FL, RL, FR driver's seat on right RL, FR, RR, FL refer to this thread https://honda-tech.com/forums/showthread.php?t=3194933 |
