Suspension & Brakes Theory, alignment, spring rates....
Is a 12 ton hydraulic press sufficient?
Old 06-08-2011, 11:50 AM
EJ8_Man's Avatar
Default Is a 12 ton hydraulic press sufficient?
Hi,
I have an EK Civic.
Will a 12 ton hydraulic press meet the demands of pressing out my suspension bushings (all of them) or should I go bigger?
This is what I'm looking at:
http://losangeles.craigslist.org/lac...424709357.html
Thanks!
Old 06-08-2011, 11:54 AM
phunhaus's Avatar
Default Re: Is a 12 ton hydraulic press sufficient?
Yes, the pressure is enough, but those designs are ****. It will take a 2 hour job and turn it into an 8 hour nightmare. You'll discover swear words you never knew existed.
Old 06-08-2011, 12:08 PM
GagnarTheUnruly's Avatar
I'm not sure 12 tons (at least in that design) is necessarily enough to remove seized bushings. I used a 20 ton press and it had some trouble on the LCA. You might need to do some burning/cutting.
12 is plenty for installation, though.
I just put a guide in the Integra forum describing how to replace bushings. You should check it out as most of the info in the guide will apply to you:
https://honda-tech.com/forums/acura-integra-6/faq-how-replace-rear-suspension-bushings-full-guide-2944576/
Old 06-08-2011, 12:15 PM
EJ8_Man's Avatar
Good feed back. I think I'm going to play it safe and look for a 20 ton press
What is a better press design?
Thanks guys
Old 06-08-2011, 01:45 PM
phunhaus's Avatar
This doesn't utilize a press cylinder (like a jack) that sways back and forth as you try to steady it.
If you're going to use this often, here's my recommendation:
Old 06-09-2011, 10:58 AM
Gekko's Avatar
I have a 12-ton press just like the OP listed. I just used it last week to press out the UCA bushings on my Integra. Didn't have any issues.
Old 06-09-2011, 12:10 PM
UCA bushings are significantly easier to remove than LCA bushings. But I know some people have gotten LCA bushings out with the 12 ton press also. I also know some people haven't been able to :/
Of course, there are other ways to get the bushings out or to weaken them to make extraction easier.
Old 06-09-2011, 01:23 PM
EJ8_Man's Avatar
Good feedback, thanks guys
Old 06-10-2011, 05:04 AM
kyden's Avatar
my friend's acura dealer only has a 12 ton press.
Old 06-10-2011, 06:39 AM
phunhaus's Avatar
They probably never do bushings. In fact, they probably never INSPECT bushings outside of the front compliance bushings on RSX's and newer cars.
Old 06-10-2011, 06:46 AM
kyden's Avatar
they do. its also been used to do bushings on my car.
Old 12-18-2012, 02:03 AM
DaveBCRV2's Avatar
I'm about to buy a 20 ton press and notice that a few have a sliding ram..which would seem a bonus - as long as the ram can be securely locked in place. Has anyone any experience of this specific type of press?
Thanks in anticipation
Old 12-20-2012, 08:37 AM
Master Detailer
98civdx's Avatar
20 ton wouldn't budge my bushings. I ended up burning them out.
With that said, I did UCA bushings for my buddy with my 20 ton. Worked like a champ. I would try with the press, if it doesn't work burn them.
Old 12-25-2012, 04:16 AM
blackeg's Avatar
Originally Posted by solbrothers
i used the harbor freight 20 ton press to do my bushings. some i had to burn out. no big deal
ive got one in my garage currently. with coupons it was like 150 bucks and i split it with 2 other friends. we have use it on anything from honda lca bushings and wheel bearings to balljoints on my full size truck to removing seized pins on a case backhoe.
Littleton
10-18-2003 08:58 AM
ODX
11-27-2001 04:37 AM
Quick Reply: Is a 12 ton hydraulic press sufficient?
