ITR brakes w/ 36mm hubs 100x4
Need a little something for that special late 90's Teg. or Civic in your life, but on a budget?
I got you covered this year. PM any questions for more detail.
$500 all together (picked up, Sherman Oaks)
Integra ('97 LS) Front knuckle (L\R)
Karcepts 36mm hubs w/ ARP studs (yep keep the 4 lug but run RSX-S or ITR axles that handle real power)
New Koyo wheel bearings (back to a factory smooth ride again without the pain of removing your inner bearing race)
New OEM lower balljoints (just the cherry on top)
Dust shield modified to fit ITR caliper
Integra ('97 LS) Rear (abs) trailing arm (L\R)
Duralast Civic Si 260mm rotor
4x100 Hub
Dust shields
Duralast Mini Cooper 282mm rotor
ITR Front Calipers (A1 Cardone, ultra premium reman. come powder coated for durability)
EBC Greenstuff pads
ITR Rear Calipers (These came with a 5 lug conv. kit, look fine you may want to do seals and give them a good cleaning)
ITR parking brake bracket (for those prior to 98 these are a b*tch to find, remans don't include them any more)
EBC Greenstuff pads
ITR parking brake cables
Caliper covers
Optional OEM Civic Alloy Wheels 15x6 et45 (clears ITR brakes, pretty minor scratching but there is some)
BFGoodrich Sport Comp2 195/55/16 (Balance w/ good tread)
Honda Center Caps
ABS Senors (These also came with a JDM ITR 5 lug kit, most are cut but will throw in)
Random OEM mounting hardware (I don't want to say everything is there but its definitely a good portion)
All the goods
4x100 Hub
Dust shields
EBC Greenstuff pads
EBC Greenstuff pads
Caliper covers
Honda Center Caps
All the goods
Bonez21
09-06-2012 08:20 PM
Lissav
29
03-17-2006 11:07 AM
