KY: B18C1 Full powertrain FS $1200
Nearly ready to be removed by DESY photowerks, on Flickr
For sale just about everything you may need to swap in a B series.
Special note: BRING A HOIST or tall jack I suppose could work. Motor is ready to come out only being held in place by upper 2 mounts.
Motor: Unsure on mileage but is a OBD1 b18c1 p72. Motor ran well before pulled but was burning oil. Compression test was 220-160-180-180. Suspect valve seal the culprit but could be rings. Swapping motors so no need to tare down motor to find out for sure. Motor revs smooth and was starting on first crank.
Transmission: 5spd GSR trans with no lsd. No grinds, slips, or quirks. Again mileage unknown.
Other things included: mounts, engine harness, ecu, axles (both good), Megan Racing 4-2-1 header, and whatever else I have laying around that's been taken off.
Bring a hoist, and cash!
Located just north of Lexington Ky. About an hour south of Cincinnati Ohio and an hour east of Louisville Ky.
