gokart
i built a d series gokart but i need a gas tank. any suggestions if i should u a civic gas tank or fuel cell. and where could i get it for cheap. im on budget($400, spent $250)
Definlty not a full tank from a car, depending on what you call a go kart. Just get a fuel cell off ebay, as long as it holds gas it should work. I was real close to using a milk jug for my tank but it wasn't close to running and had some buddies make me one.
http://cgi.ebay.com/ws/eBayISA...&rd=1
http://cgi.ebay.com/ebaymotors...33556
pics defently, i have a couple of two-seater gokarts that need engines and i also have a couple of engines laying around... this would be killer...hook up with pics and info on how you did this...thanks
any body have part they don't need in New Jersey around Linden would be better.
Il buy master cyclinder and power booster for brakes.and i need clutch master cyclinder from some one. i need wire harnes for d series my is fucked up, i need to make a new one.and steering colum mine is two pipes with a spin at the ends .
Any body could help i would really appreseate (sp)!!!!!!!!!!
Why dont you simplify the steering and get rid of the rack and pinion and go with a go kart type steering system.
Are you using he whole suspention system too? Post some pics up, souds like your making it harder than it needs to be...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kinkbmx159 »</TD></TR><TR><TD CLASS="quote">the regular go kart steering would snap with all that wieght in the front. plus i think it would be really hard to turn. but good idea tho
go kart type... All he has to do is get bigger tie rods/ joints.
wheres the pics? I also call bs, prove me wrong...
</TD></TR></TABLE>go kart type... All he has to do is get bigger tie rods/ joints.
"All the weight in the front"...do you mean this'll be a FWD go-kart? This IS sounding a bit fishy...
Edit: Although I don't know why someone would lie about something like this...
Re-edit: Although then again, someone did lie about owning an R, and posted a bunch of pics of someone else's car...
Randysi
May 15, 2012 06:12 PM
