Alignement for a drop suspension
Old Sep 22, 2004 | 11:25 AM
DaveSi677's Avatar
Default Alignement for a drop suspension
I am wondering do I need to have a camber kit to be able to have an alignement done. Right now my car is seating on neuspeed race and toxicos. So wondering what I should do????? Need help fast !!!!!!!!!!!!
Dave
Old Sep 22, 2004 | 11:27 AM
Marauder's Avatar
Default Re: Alignement for a drop suspension (93SiVtec677)
Lowered an inch or more, I'd say yes!
Old Sep 22, 2004 | 11:34 AM
DaveSi677's Avatar
ok like a little more explaining!!!!! plz
Dave
Old Sep 22, 2004 | 11:38 AM
handa's Avatar
if you lower your car like to the ground or 1finger gap, etc....i'd recommend getting camber kits.
Old Sep 22, 2004 | 11:40 AM
gftgrill's Avatar
Default Re: Alignement for a drop suspension (handa)
you pretty much only need an alignment if you like having a car that goes perfectly straight. and you don't want your tires wear out on the sides fast.
so if you want both of those get an alignment.
Old Sep 22, 2004 | 12:55 PM
keSatt247's Avatar
Agreed. I lowered my car 2 inches, got it aligned, the next day it was runnin me off the right side of the road It's back to stock height now and I still have problems w/ it..could be due to the fact I let a complete idiot slave over my suspension.
Old Sep 22, 2004 | 01:18 PM
redlinetuning's Avatar
Default Re: Alignement for a drop suspension (gftgrill)
an alignment does NOT fix the CAMBER. All that alignment will do is fix your TOE settings, generally on a street car you want the toe settings to be as close to 0 (zero) as possible.
A camber kit on the otherhand, will NOT FIX the TOE settings. All it does is fix CAMBER. there's a huge difference between the two. All Camber does is adjust the angle at which the wheels sit perpendicularly to the ground.
PM me if you have questions.
Old Sep 22, 2004 | 01:25 PM
fkncivic's Avatar
Default Re: Alignement for a drop suspension (keSatt247)
just get an adjustable camber kit and take it to goodyear they will do a good job.
taimysho0
15
Oct 11, 2023 09:49 PM
R_Machine
Sep 23, 2003 12:27 PM
Group 03
Feb 20, 2003 07:48 AM
imported204
Sep 1, 2002 07:19 AM
5-SpeedFreak
Nov 1, 2001 09:17 AM
