help needed with swap
This is a relatively easy swap i'm told and i'm an apprentice mechanic so i'm getting used to doing basic R&I's. The car i'm swapping is a 93 civic with a D15b7 i'm replacing that with a D16Z6. Now I need someone who's done this swap to tell me what will fit what won't and what I need assuming i get the Z6 without distributor,intake,wiring(harness or ecu), and exhaust manifold.
what will fit:
exhaust, tranny, wiring harness (few mods to make it run right 4 wire, and wire up the vtec), ecu will work but suggest replacing it ASAP, alternator and all the accesories transfer over.
There is bunch of other crap that I didn't mention.
What will not fit:
Distributor, IM, driver side engine mount from b7 (you will need to trasfer over the whole engnine mount assebly from b7 to make it work on z6, if you don't have the z6 one), spark plug wires
What will not fit:
95Hatch_209
Oct 22, 2015 03:05 PM
jackhunt321
Sep 29, 2006 10:06 AM
-[95cxhatch]-
Jul 22, 2003 01:10 AM
