i have no codes and my vtec is not working need some help thanks
Old Sep 20, 2004 | 02:38 PM
drvfast's Avatar
Default i have no codes and my vtec is not working need some help thanks
my car has no vtec i am running a p30 and it is have a xsi in my crx i am using my stock vss that is on the ys1 tranny i think i am going to have to get an electrical vss but i want to know if there is a way to use the stock one
Old Sep 20, 2004 | 02:54 PM
4drEF's Avatar
Keyboard Humorist
Default Re: i have no codes and my vtec is not working need some help thanks (drvfast)
Are you getting a CEL and ECU codes?
Old Sep 20, 2004 | 05:21 PM
mar778c's Avatar
Community Builder
Community Influencer
Check, to see if the air temperature sensor is plugged in. I've seen this problem before were the vtec will work if it is jumpered but won't kick in on it's own.
Vtec requires several things to work: speed sensor, oil pressure, air temperature, and one other thing I can remember.
Old Sep 22, 2004 | 08:18 AM
drvfast's Avatar
Default Re: i have no codes and my vtec is not working need some help thanks (mar778c)
it is pluged in
Old Sep 22, 2004 | 09:07 AM
crx_88_si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">Check, to see if the air temperature sensor is plugged in. I've seen this problem before were the vtec will work if it is jumpered but won't kick in on it's own.
Vtec requires several things to work: speed sensor, oil pressure, air temperature, and one other thing I can remember. </TD></TR></TABLE>
water temp, not air temp
vtec needs Water Temp (coolant), Vehicle speed, Oil Psi, and RPM.
Old Sep 22, 2004 | 10:18 AM
Redline130's Avatar
Check the screen in the VTEC solenoid. The screen could be clogged with grime and not allowing enough oil pressure into the head. This is just something that I've seen many times before when there is no VTEC activation, but no codes are thrown either.
Old Sep 22, 2004 | 03:11 PM
Jaker's Avatar
Make sure the speed pulser in the instrument cluster is wired into the harness you're using for OBD0 to OBD1.
Old Sep 22, 2004 | 05:15 PM
mar778c's Avatar
Community Builder
Default Re: i have no codes and my vtec is not working need some help thanks (crx_88_si)
Thanks for reminding me water temp is correct but you also have to have the air temp sensor operating.
stehigs321
15
Mar 1, 2019 05:16 PM
TristanW10
Mar 15, 2010 03:33 PM
JsSIR
Jul 14, 2008 08:14 PM
EK FLY
Jan 21, 2006 02:26 PM
civicseth
16
May 18, 2005 08:51 PM
