oil feeds question
Old Sep 20, 2004 | 05:55 AM
maxspeedhonda's Avatar
Default oil feeds question
I am currently using a tee off the back of the block to feed my turbo, never had a problem with it. I just bought an electrical autometer oil pressure gauge and I need to install the sender. What are the rest of the turbo guys doing to supply oil to both the turbo and the gauge?
Old Sep 20, 2004 | 05:58 AM
FOrSfEd's Avatar
Default Re: oil feeds question (maxspeedhonda)
I'm using a custom oil distribution block.
Old Sep 20, 2004 | 06:04 AM
Default Re: oil feeds question (FOrSfEd)
would you happen to have a pic of it?
anyone use one of those oil filter sandwhich things in this situation? I know there has to be quite a few people running an elect oil pressure gauge with their turbo.
Old Sep 20, 2004 | 06:16 AM
FOrSfEd's Avatar
I can get a pic when I get home. I do know people run the sandwich adapters and they seem to work fine as well. Basically what I'm using is a vaccum manifold that I got for around 14.00 from http://www.mcmaster.com. I have a -6an feed line into the distribution block then I have my oil pressure sending unit and my oil turbo feed line with a -3 fitting coming out. Seems to work well.
Old Sep 20, 2004 | 08:45 AM
bump
Old Sep 20, 2004 | 09:03 AM
xenocron's Avatar
http://www.xenocron.com/carpics/option2.jpg
This is what I used for my oil feed setup. Actually, I used the Flamenco-T oil feed and then just added the extra line a a couple of fittings so that I didnt have that big heavy sending unit stressing the back of my block.
FOrSfEd, do you have the McMaster Part# for your distribution block?
Old Sep 21, 2004 | 06:42 AM
Default Re: oil feeds question (xenocron)
bump
Old Sep 21, 2004 | 06:51 AM
FOrSfEd's Avatar
I went with the smaller block for the oil the part number is 5469K121
Old Sep 21, 2004 | 10:32 AM
Flamenco-T's Avatar
This will make your life easier...
Firewall Oil Supply Distribution Block
$ 30 shipped..
Give me a call if interested, 888-887-2658
Stan
Old Sep 22, 2004 | 05:26 AM
Default Re: oil feeds question (Flamenco-T)
Nice looking setup, I will be getting in touch with you today...
TravisBiggie
Aug 20, 2013 07:48 PM
ImPuLsIvE
Jun 14, 2008 05:38 PM
nukem384
Mar 5, 2003 06:11 PM
slingshotsi
Sep 9, 2001 06:11 PM
quikrpm'z
Jul 25, 2001 12:15 PM
