problems with the turbo prelude
Old Sep 19, 2004 | 08:53 PM
Xbstd23X's Avatar
Default problems with the turbo prelude
i just replaced my head gasket and now there is a ticking in the head not sure whats causing that. and when i drive it first gear is fine but second on bogs really bad anyone have any clues on whats wrong.
Old Sep 19, 2004 | 09:25 PM
safe driver's Avatar
Default Re: problems with the turbo prelude (Xbstd23X)
checked the timing?
Old Sep 19, 2004 | 09:26 PM
PrecisionH23a's Avatar
Sounds like your valves are too loose. Adjust them.
Old Sep 20, 2004 | 01:13 PM
Xbstd23X's Avatar
Default Re: problems with the turbo prelude (PrecisionH23a)
would that cause it to bog down
i also found an oil leak that i have no idea where its comin from it drops down and hits the cross member
Old Sep 20, 2004 | 04:41 PM
Johnnytech's Avatar
Are you 100% sure you put the head gasket on correctly?
Old Sep 20, 2004 | 04:47 PM
Xbstd23X's Avatar
Default Re: problems with the turbo prelude (Johnnytech)
not 100% but im pretty sure
and i adjusted the vavle lash and its still ticking
Old Sep 21, 2004 | 08:43 PM
Xbstd23X's Avatar
well im goin to readjust my vavles and it should be good
but when i drive it
it feels jumpy like when your learnin how to drive a stick
anyone got any clues on what could be wrong
Old Sep 21, 2004 | 08:49 PM
preludeez's Avatar
does your CEL come on?
Old Sep 21, 2004 | 08:52 PM
Xbstd23X's Avatar
Default Re: problems with the turbo prelude (preludeez)
nope no cel
its just mid rpms to
Cole Peters
Sep 28, 2015 05:53 PM
Cummins4LF
Sep 11, 2015 07:12 PM
fourdoorteg
Jan 21, 2010 07:15 PM
Trellis
Sep 18, 2004 07:58 PM
GreenMachineRex
Mar 15, 2004 01:47 PM
