NGK BCPR7ES-11 Spark Plug Gap?
Old Sep 19, 2004 | 07:27 PM
mrnicolas's Avatar
Default NGK BCPR7ES-11 Spark Plug Gap?
I did some searching on here and I did not come up with the correct gap for these ngk BCPR7ES-11 plugs that I am using on my d16z6 with a jrsc. I called jackson racing and they told me they were pregapped. Upon checking the gap on them, they are all between .39-.41 What exactly are these supposed to be gapped at? If they all were gapped the same, I wouldnt worry about it. Being told they are all pregapped and they are all a little different, I want to make sure exactly what I need to gap these at.
Thanks in advance.
Old Sep 19, 2004 | 07:48 PM
showtymers619's Avatar
* B A N N E D *
Default Re: NGK BCPR7ES-11 Spark Plug Gap? (mrnicolas)
just to make you feel better.. gap them to .40 LOL
Old Sep 19, 2004 | 07:55 PM
BEEYOND's Avatar
Default Re: NGK BCPR7ES-11 Spark Plug Gap? (ShowTymers619)
dude it isn't .41.... it should be "0.041"
.41 is nearly almost one half of an inch....... |<-->| <------now that is about the distance you are mentioning......
not being a d1ck just letting you know bro....
high boost go .025-.030 .... lower boost level 5-10psi you are good at .035-.040
Old Sep 19, 2004 | 08:27 PM
Muckman's Avatar
Moderator in Chief
4.0"
Old Sep 19, 2004 | 08:50 PM
94dxt's Avatar
Default Re: NGK BCPR7ES-11 Spark Plug Gap? (Muckman)
try .04, if you get any missing try .038, if no missing try .042. Just play w/it a little.
Old Sep 20, 2004 | 07:03 AM
mrnicolas's Avatar
Default Re: NGK BCPR7ES-11 Spark Plug Gap? (nicholashang87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicholashang87 &raquo;</TD></TR><TR><TD CLASS="quote">dude it isn't .41.... it should be "0.041"
.41 is nearly almost one half of an inch....... |&lt;--&gt;| &lt;------now that is about the distance you are mentioning......
haha, sadly enough I realized that this morning after looking at it. Thanks for pointing it out. lol.
so I think I will put them somewhere between .0035 and .0040. Thanks for the advice.
Old Sep 21, 2004 | 06:29 AM
mrnicolas's Avatar
just so in case any one was searching for this in the future, the correct gap I found after a few phone calls is .0036"
Old Sep 21, 2004 | 07:10 AM
Enthalpy's Avatar
Default Re: (mrnicolas)
i hope you meant 0.036"
BTW the -11 on the end of the plug part number means they are pregapped to 1.1mm. mmmmkay
Old Sep 21, 2004 | 08:32 AM
mrnicolas's Avatar
ok, pu tthe decimal in the wrong place.
yes I know they were supposed to come pregapped, but when they all were either 0.039 - 0.041 they are not gapped right for my application. Thats more than 1.1mm.
Old Sep 21, 2004 | 11:13 AM
Enthalpy's Avatar
1.1mm is 0.043307"
wtsapexipowerfc
Sep 18, 2010 01:37 AM
i dunno
Honda S2000
Oct 13, 2006 01:02 PM
sleepystyle
Mar 29, 2006 07:50 PM
swissturbo
Jun 14, 2002 11:33 PM
keys
Aug 8, 2001 07:52 AM
