Idle Air Control Valve
Old Sep 19, 2004 | 05:46 PM
kandekilla's Avatar
Default Idle Air Control Valve
I am throwing a code 14. Which is the IACV. Check the valve. Resistance is with in spec. Got another one for the heck of it and still doing the same thing. Idle sits and jumps up and down rapidly. ANyone know what else might be ther problem if the valve itself is fine but the ecu still throws the code?
Old Sep 19, 2004 | 06:14 PM
Full Race A6's Avatar
Default Re: Idle Air Control Valve (kandekilla)
soak it in carb cleaner
and you reset your ecu after changing them right?
Old Sep 19, 2004 | 06:47 PM
kandekilla's Avatar
Default Re: Idle Air Control Valve (Full Race A6)
yeah I have reset the ecu a few times now.
Old Sep 19, 2004 | 06:51 PM
AgentJam's Avatar
could be a cut wire? It's either...
A) ECU (99.9% it's not)
B) IACV itself (if you swap known goodie and problem still exists then no)
C) short/break in sensor wires (chase 'em!)
Vince
Old Sep 19, 2004 | 06:55 PM
91 HONDAsaurus rex's Avatar
Default Re: Idle Air Control Valve (AgentJam)
does it have 2 vaccum lines that connect under. If you havnt checked then I would say connect them if you havnt.
Old Sep 19, 2004 | 06:58 PM
2point2's Avatar
check your coolent level.
Old Sep 19, 2004 | 07:56 PM
coot_er's Avatar
Default Re: (2point2)
i had a code 14 because my wiring came undone . after taking off the iacv and cleaning it i found out that when i lengthen it, the wire came out of the butt conector.
Old Sep 20, 2004 | 05:43 AM
kandekilla's Avatar
Default Re: (coot_er)
anyone know which wire it is in the ecu? I can't find my book to find the pin list for the ecu.
Old Sep 20, 2004 | 06:11 AM
SPORT INJECTION's Avatar
if you do soak it in carb cleaner... be sure to take the small rubber gasket off. it will warp and distort after soaking... i know this
Old Sep 20, 2004 | 10:05 AM
Default Re: Idle Air Control Valve (SPORT INJECTION)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPORT INJECTION &raquo;</TD></TR><TR><TD CLASS="quote">if you do soak it in carb cleaner... be sure to take the small rubber gasket off. it will warp and distort after soaking... i know this</TD></TR></TABLE>
lol ****, I didnt know this... mine must be fubarred
Old Sep 20, 2004 | 10:16 AM
crx_88_si's Avatar
ROFL, check your wiring.
and those are NOT VACUUM LINES on the bottom, they are coolant lines.
Old Sep 20, 2004 | 05:24 PM
kandekilla's Avatar
I plan on going through the wiring. I need which pin the wire is in the ECU so I can try bypassing it to check and make sure that is the problem.
Old Sep 21, 2004 | 06:39 AM
kandekilla's Avatar
ok, new theory. I bypassed the wires from the ECU to the EACV. No change. ECU maybe?
Old Sep 21, 2004 | 06:53 AM
crx_88_si's Avatar
Default Re: (kandekilla)
bypassed,... as in unplug the wiring @ the ecu? and it still threw a code?
of course it would... cuz u disconnected the iacv
Old Sep 21, 2004 | 07:48 AM
senpai's Avatar
Default Re: (crx_88_si)
Just because a code 14 comes up doesn't necessarily mean it's the IACV
It can be as simple as low coolant
Old Sep 21, 2004 | 02:10 PM
gringo7718's Avatar
Default Re: (senpai)
check the wiring. you can test the ground wire easily. you will see a blk/yel wire. this is ground. use a test wire, connect it and ground the sensor. reset ecu etc..... test
Old Sep 21, 2004 | 06:38 PM
kandekilla's Avatar
no If it was a short in the wiring somewhre then I bypassed that. Clipped the wire form the eco to the EACV and ran ti directly to the EACV. There by bypassing the wiring harness. My coolant isnt low but why would having low coolant jump my idle up and down? I have had low colant in the other 6 crx I have owned since 99 and never had the idle do this. The only time my idle did this was a blown head gasket, but I never threw any codes. I plan on checking the head gasket this weekend jsut to make sure its not that.
gorsey
Aug 22, 2011 10:45 AM
h22blklude92
Jun 14, 2011 05:23 PM
kyhatch
27
Jan 13, 2009 04:15 PM
dad0c402
May 5, 2007 08:06 PM
ITR41
Dec 16, 2001 04:15 PM
