Error code 14 and misfire - i'm out of idea's ?
Old Aug 22, 2011 | 07:20 AM
gorsey's Avatar
Default Error code 14 and misfire - i'm out of idea's ?
Pretty much stumped on this one. I'm thinking of trying another ECU.
Check out this vid of the misfire. http://imageshack.us/clip/my-videos/828/4ut.mp4/
I'm getting error codes 14 and 20. I've checked the Idle valve, replaced tps and o2 sensor. Also checked for vacum leaks and seems all good.
It doesn't start very well. Sounds like its going to stall but just about recovers to idle.
anyone got any idea's
Old Aug 22, 2011 | 10:32 AM
gorsey's Avatar
Default Re: Error code 14 and misfire - i'm out of idea's ?
so i've had another play around.
I maually grounded the iacv earth wire while the engine was running. The idle jumped up to 1500 rpm (still misfiring). I'm guessing the problems are seperate so for now i want to get all the error codes fixed.
Should the iacv be open (high idle) when the car is cold? I'm assuming the earth from the iacv is broken somewhere.
Would it work to wire the earth from the iacv to pin A9 on the ecu to test?
I'm just not sure when the iacv comes into play - most answers involve bringing the car up to temp but I would expect this to work when the car is cold???
Old Aug 22, 2011 | 10:45 AM
gorsey's Avatar
found this info. interesting
http://ecomodder.com/forum/showthrea...ained-967.html
h22blklude92
Jun 14, 2011 05:23 PM
dragon_lowrider
Sep 22, 2010 10:55 PM
aksdgff
Sep 3, 2010 06:14 AM
saucyhatch
Feb 11, 2004 07:27 AM
Rain_man
Apr 8, 2003 08:45 AM
