Oil in coolant burning oil.
Old Sep 19, 2004 | 02:50 PM
b16 matt's Avatar
Default Oil in coolant burning oil.
I got oil in my coolant and i burn oil i think. I changed my head gasket and it didnt fix the problem. What else could it be and how could i fix it?
Old Sep 20, 2004 | 04:37 AM
eg6T's Avatar
Default Re: Oil in coolant burning oil. (b16matt)
after installing the new head gasket,did you drain the coolant?
Old Sep 20, 2004 | 10:13 AM
inspyral's Avatar
Did you make sure the head isn't warped? Did you do the same for the block deck?
Old Sep 20, 2004 | 10:20 AM
b16 matt's Avatar
Default Re: (inspyral)
I had the head resurfaced when i had the block built.
Old Sep 20, 2004 | 10:39 AM
Stewie's Avatar
Default Re: (b16matt)
Information about your setup would help a lot. When you replaced the gasket, did you change the o-ring for the oil control orifice?
Old Sep 20, 2004 | 11:37 AM
m R g S r's Avatar
Did you torque the head bolts in the right sequence? Are you using ARP headstuds?
Old Sep 20, 2004 | 11:41 AM
b16 matt's Avatar
Default Re: (m R g S r)
b16 9:1 ductile iron sleaves eagle rods. No i didnt replace the o-ring damn do you think this could be the problem. I definetly did it in the correct order, but the psi on the bolts might be wrong what is it on the arp's. I couldnt get a straight answer from arp so i did it to oem specs. Where is that oil ring you speak of?
Modified by b16matt at 8:55 PM 9/20/2004
Old Sep 20, 2004 | 12:10 PM
Stewie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16matt &raquo;</TD></TR><TR><TD CLASS="quote">b16 9:1 ductile iron sleaves eagle rods. No i didnt replace the o-ring damn do you think this could be the problem. I definetly did it in the correct order, but the psi on the bolts might be wrong what is it on the arp's. I couldnt get a straight answer from arp so i did it to oem specs. Where is that oil ring you speak of?
Modified by b16matt at 8:55 PM 9/20/2004</TD></TR></TABLE>
On the block's mating surface, toward the back of the block, is where the oil control orifice is located. If you didn't replace its o-ring, you could have 50+psi of oil going to your HG. The oil could be finding it's way to coolant and mixing.
Old Sep 20, 2004 | 02:51 PM
b16 matt's Avatar
Default Re: (Stewie)
**** that might be missing all together. SOB
Old Sep 20, 2004 | 05:15 PM
b16 matt's Avatar
Is it possible that over-torquing of my head studs would cause a head gasket leak, and if so what shoul i do?
Old Sep 20, 2004 | 06:00 PM
turbosi03's Avatar
**** I didn't replace that O-ring when I put my motor together... so does that leave good chances of me having the same problem?
Old Sep 23, 2004 | 11:02 AM
b16 matt's Avatar
Default Re: (turbosi03)
Well I did a leak down test and i have leakage between 3 and 4. So the good news is i found the problem the bad news is it could be a number of reasons.
Dropped wall head gasket, etc. I guess ill just tear it appart this weekend and find out. Wish me luck
Old Sep 23, 2004 | 11:03 AM
b16 matt's Avatar
Does anyone know the torque specs on arp's for b series?
Old Sep 23, 2004 | 11:19 AM
chad174's Avatar
I believe my GSR ARP studs were 67 ft. lb. I did them to 20 ft lbs, then 50, then 70. worked good for me.
98civc123
23
Sep 8, 2021 08:14 PM
sshh
Apr 29, 2011 05:59 AM
redh22alude
Dec 30, 2008 09:32 AM
civicjdmb16a
Jan 14, 2007 01:55 PM
94integragsr
Jun 3, 2006 11:13 AM
