headwork and now the dizzy wobbles?
ok so i replaced all the valve stem seals on my d16 crx si head (on a d15 bottom end) and after putting it all back together and hooking everything back up it wont start. i just noticed it has a CEL code 10 for the intake air temp sensor, but i have no way of testing the ohms of the sensor. the thing that scares me the most is the distributor seems to wobble back and forth when it turns over. almost like the cam or something in the dizzy is bent.
any ideas on what to do?
From: I told you to wait in the truck in Texas, United States
Sounds like maybe the bearings in the distributor are bad..
Look inside the cap and see if the rotor or the cap have been damaged.
thenext
17
Sep 19, 2011 04:47 PM
