Dynoed... opinions welcomed.
Old Sep 19, 2004 | 10:02 AM
TypeRKoncepts's Avatar
Default Dynoed... opinions welcomed.
Sorry for the size, if i wasn't at work i'd resize.
164whp/146tq. Was expecting a little more but seems like its running strong from what others have told me (but a little lean top end?). Hopefully i'll open up the intake and exhaust a bit more (pretty restrictive at the moment) and get some better numbers in the future.
1995 JDM H22a, ACT street light flywheel, generic intake (but 2.5" intercooler pipping), header and some 2 1/4" exhaust.
Old Sep 19, 2004 | 12:05 PM
satan_srv's Avatar
Default Re: Dynoed... opinions welcomed. (TypeRKoncepts)
#1 It seems you've used the STD adjustment...can you put it in SAE? It will be lower. And put your graph in RPM not speed
#2 your a/f ratio seems way to high, you shoul be in the 13.0:13.7 range most of the time. You are likely losing power from running too lean especially in vtec. You should dyno again eitgher with a V-AFC to add fuel, or try fuel pressure tuning. Either way you are running too lean
Old Sep 19, 2004 | 12:39 PM
it was a local shops dyno day so no i can't/don't know how to put it in SAE.
Also if u look its two seperate pulls, one pull has the speed the other has the rpms...
Old Sep 19, 2004 | 01:38 PM
ek4hatch's Avatar
Default Re: (TypeRKoncepts)
looks good man!!
BLK99VTECR
Mar 2, 2004 04:15 AM
95TurboLS
Sep 2, 2003 05:58 PM
hybrid901
Aug 20, 2003 06:44 AM
Excelerate
Jun 25, 2003 01:15 AM
burninCRX
Feb 10, 2003 08:31 AM
