531whp@24psi
Old Aug 18, 2003 | 07:52 AM
hybrid901's Avatar
Default 531whp@24psi
First off thanks to Polk Performance for the use of the dyno. They had a dyno day on Sat that I went to after work and only made 420whp@19psi with the same tune I made 484@19psi at Jotech a few months back. It was low/mid 70's in Dallas and 103 in Little Rock at the dyno. I was also tuned on 114 and was running 116. The combination of the to had my car running dead rich. The whole first run I was richer than 10.5 compared to 11.8-12.2 at Jotech. I knew my #'s would be alittle low because of the heat but I couldn't believe I needed to take out that much fuel. After pulling out 4-5% fuel it ended up making 452@19psi. After it was all said and done I made 531whp/357tq @24psi. I was only tuning with my techedge wideband so I didn't do any fine tuning per rpm but I'm between 10.8-11.7 from 5500-8500 and it goes pretty rich after 8500. I will post a chart up when I get home tonight.
Modified by hybrid901 at 1:07 AM 8/19/2003
Old Aug 18, 2003 | 07:55 AM
93LSivic's Avatar
Default Re: 531whp@24psi (hybrid901)
Nice numbers man!! What compression ratio and bore are you?
Old Aug 18, 2003 | 07:56 AM
hybrid901's Avatar
Default Re: 531whp@24psi (93LSivic)
84.5mm and right around 10:1-10:3
Old Aug 18, 2003 | 07:59 AM
VTC_CiViC's Avatar
DAYUM!
You deserve a few
Old Aug 18, 2003 | 08:03 AM
FOrSfEd's Avatar
Default Re: 531whp@24psi (VTC_CiViC)
Wow those are great numbers.
DIRep972's Avatar
Smarter than you
nice josh. That heat is a killer. I can't believe it made such a big difference w/ a/f. thats crazy. just remember to richen it back up come winter
Old Aug 18, 2003 | 08:08 AM
gitwidit's Avatar
Freakin awesome, can't wait to see the chart
Old Aug 18, 2003 | 08:17 AM
TurboDANDEE's Avatar
what turbo and size are u using? nice numbers.
Old Aug 18, 2003 | 08:19 AM
hybrid901's Avatar
Default Re: (TurboDANDEE)
Its a sc61, E housing, .63 stage 5 full boost around 4600.
Old Aug 18, 2003 | 08:28 AM
SEFIxCivic's Avatar
what kinda of computer are you running sounds like you need to modify the air temp compensation.
Mad
good #'s. i'll bet that turbo spools up very fast with that CR. BTW, what was your timing at 24 psi?
Old Aug 18, 2003 | 08:40 AM
mos's Avatar
mos
Damn. 10.3:1 and 24psi... Yer karr pwnz my karr.
You think 9.3:1 and 9psi will make 500?
Old Aug 18, 2003 | 08:54 AM
The sweed's Avatar
How much can you do on pump gas?
Teg4e's Avatar
Default Re: 531whp@24psi (mos)
very nice numbers, what do you make on pump gas?
Old Aug 18, 2003 | 09:12 AM
hybrid901's Avatar
Default Re: 531whp@24psi (Teg4e)
14psi on pump gas 414whp.
Old Aug 18, 2003 | 09:27 AM
.nate's Avatar
Badass numbers Josh... cant wait to see the chart.
Old Aug 18, 2003 | 09:29 AM
xJ.SLOTHx's Avatar
Old Aug 18, 2003 | 09:51 AM
Teg4e's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid901 &raquo;</TD></TR><TR><TD CLASS="quote">14psi on pump gas 414whp.</TD></TR></TABLE>
Old Aug 18, 2003 | 10:14 AM
teamrocket si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid901 &raquo;</TD></TR><TR><TD CLASS="quote">531whp/357tq @24psi</TD></TR></TABLE>
Old Aug 18, 2003 | 11:12 AM
jdm_kenji's Avatar
what kind of turbo are u using?
Old Aug 18, 2003 | 11:16 AM
LsTurbo91's Avatar
nice! what kind of timing are you running up top?
Old Aug 18, 2003 | 11:30 AM
hybrid901's Avatar
Default Re: 531whp@24psi (LsTurbo91)
Turbo specs are up top. Timing is 20 degrees at 25psi.
Old Aug 18, 2003 | 11:37 AM
Jeff33S's Avatar
Default Re: (hybrid901)
Yea Danny at Polk has been telling me about your setup nice numbers. He wants me to run a similar turbo in the build I'm doing, but then again I gotta get the block back first
-Jeff-
Old Aug 18, 2003 | 11:45 AM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid901 &raquo;</TD></TR><TR><TD CLASS="quote">Its a sc61, E housing, .63 stage 5 full boost around 4600.</TD></TR></TABLE>
Next purchase
Old Aug 18, 2003 | 01:46 PM
Boost2NA's Avatar
Default Re: (Blown90hatcH)
Very nice numbers man
Polk Performance
Also if they used the same dyno I think they did its a mustang dyno. If thats the case you will put out higher numbers on a dynojet.
Once again great numbers
to Danny and Polk Performance.
