> how often does one need to clean the vtec solenoid?
i was wondering if there was a proper procedure and time/mileage interval for cleaning the vtec solenoid on B18C1s.
that is all.
thanks.
that is all.
thanks.
i would like to know the answer as well.....
ive been noitcing a few times that when im driving into vtec range it does not kick in for some reason.......
anyone have any directions on cleaning it?
Hmm underneath my hood the guy the owned the car before sprayed clear coat all over everything, like the distributor cap, and vtec solenoid. It seems when he sprayed it though he didn't clean it off first. So theres nice layer of dust/oil or something trapped underneath the clear coat. Anyone know a way I can remove the clear coat safely off the vtec solenoid?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks »</TD></TR><TR><TD CLASS="quote">its all in your hands how often you change your oil
and how often you check the vtec solenoid filter
if there is build up just clean it up..</TD></TR></TABLE>
keep that oil cahnged and filter changed and you should be ok there should be no reason you need to clean it out. its not in the service manual saying to change or clean after so many miles
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slooogsr »</TD></TR><TR><TD CLASS="quote">
first check your oil level and pressure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xymox007 »</TD></TR><TR><TD CLASS="quote">
first check your oil level and pressure.</TD></TR></TABLE>
i always keep tabs on that, oil pressure is great as well...... just around 136k miles on it.
