Akari Motorsports Dry Film Lubricant 100miles No Oil Test
Old Sep 18, 2004 | 08:13 PM
AkariMotorsports's Avatar
Default Akari Motorsports Dry Film Lubricant 100miles No Oil Test
In this test we Coated the piston skirts, rod and main bearings and broke in an engine before the abuse. We then drained all the oil and drove the engine for 100 miles without any oil to see what happened. No spun bearings, no piston slap and very little rod knock when this engine was disassembled.
As you can see all our the bearings were in VERY good condition to be run without oil because the dry-film lubricant is a solid film lubricant the bearings were barely scared because the bearings still had lubrication after the oil was all drained. The darker areas are the remains of the dry-film lubricant that goes below the surface of the metal during our curing process. We expected after this abuse that all of the
dry-film would be burned off but as you can see for yourselves this greatly reduces engine failure during
"unexpected" situations.
The pistons skirts were coated with our dry-film lubricant as well and you can see that the piston and walls defiantly did not like the friction from lack of oil. Normally there would be considerable piston slap and the sides of the pistons would be scared and in some places melted. The dry film added a layer of protection and the surface was completely smooth, not to mention the cylinder walls were not gouged or rough at all. No hone is going to be used there is still very visible cross-hatch.
The last thing to look at is the rod journals that were uncoated for this test to see what evidence of friction there would be. As you can see all the journals were in great shape, some need to be repolished but for the most part there is very little scaring from friction.
Old Sep 18, 2004 | 08:51 PM
S2KP's Avatar
no oil for 100 miles?! thats some scary ****.
Old Sep 18, 2004 | 09:45 PM
Kal's Avatar
Kal
Default Re: Akari Motorsports Dry Film Lubricant 100miles No Oil Test (AkariMotorsports)
Old Sep 18, 2004 | 10:04 PM
ModenaTwinTurbo's Avatar
Default Re: Akari Motorsports Dry Film Lubricant 100miles No Oil Test (Kal)
thats pretty impressive. now wheres the test with the same motor without coatings and oil. how many seconds did it last?? hahaha
Ed-
Old Sep 18, 2004 | 10:27 PM
honda9369's Avatar
Default Re: Akari Motorsports Dry Film Lubricant 100miles No Oil Test (ModenaTwinTurbo)
Old Sep 18, 2004 | 11:49 PM
Default Re: Akari Motorsports Dry Film Lubricant 100miles No Oil Test (honda9369)
Under situations with high boost or compression, a loss of oil pressure at high rpm's can lead to enough friction the bearings can be spun before the engine can even be shut off. We originaly though that we would have piston slap immediatly and then rod knock before we hit even 50 miles, this test really showed us how the diffusion (coating being absorbed into the metal at a molecular level with our curing at moderate temperature) could allow the bearings to refuse friction and operate under extreme conditions.
Old Sep 18, 2004 | 11:56 PM
twkdCD595's Avatar
big to you guys for doing this kind of testing, and obviously at your own expense!!!
impressive.
Old Sep 19, 2004 | 02:16 AM
Bambooseven's Avatar
Default Re: Akari Motorsports Dry Film Lubricant 100miles No Oil Test (twkdCD595)
is this stuff intended for use w/ oil? as an added lubricant/protection? is there any depth to it? (will it throw off tolerances if not acounted for?) has it been tested w/ oil? for long periods of time?
Old Sep 19, 2004 | 05:25 AM
danl's Avatar
Banned
Default Re: Akari Motorsports Dry Film Lubricant 100miles No Oil Test (Bambooseven)
Call me a skeptic but.........
Old Sep 19, 2004 | 06:05 AM
Oyvind Ryeng's Avatar
Wow, I'm very impressed! I'd never think the poor engine would last longer than a few seconds without oil; coated or not.
Old Sep 19, 2004 | 08:53 AM
earl's Avatar
Neither the piston rings nor the cylinder walls were coated.
What is your explanation for the fact that each and every ring showed absolutely no heat build up or friction wear? It makes no sense that...to quote you...
"the cylinder walls were not gouged or rough at all. No hone is going to be used there is still very visible cross-hatch."
It is the heat and friction of the rings against the wall that creates the wear problem...not the skirt, coated or not.
Old Sep 19, 2004 | 08:59 AM
Ri5e's Avatar
Default Re: Akari Motorsports Dry Film Lubricant 100miles No Oil Test (earl)
Wow, 100 miles without oil...
Old Sep 19, 2004 | 09:00 AM
menkio's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">Neither the piston rings nor the cylinder walls were coated.
It is the heat and friction of the rings against the wall that creates the wear problem...not the skirt, coated or not.</TD></TR></TABLE>
Old Sep 19, 2004 | 01:13 PM
xenocron's Avatar
So what were you hoping to accomplish with this test? What did you guess would happen? What really happened?
I'm really understanding the point to this thread. It's all good that you went out and did this test but what does it prove? That your coatings will help in case of sudden oil loss?
How were the 100 miles driven? Did you just put around town? Highway driving at high speeds (65-75mph)? Was this motor boosted? Was it freshly rebuilt with all new internals before you coated and installed all your parts?
I think you need to go into a little more depth here...
Old Sep 19, 2004 | 01:20 PM
plusONE jboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron &raquo;</TD></TR><TR><TD CLASS="quote">So what were you hoping to accomplish with this test? What did you guess would happen? What really happened?
I think you need to go into a little more depth here...</TD></TR></TABLE>
I am curious also, what was the purpose of this test?
Old Sep 19, 2004 | 01:36 PM
vtec.dc2's Avatar
Default Re: (j boy)
interesting thread, lets hear more details
thewrai6th
Nov 11, 2012 05:20 PM
campbell81
Jul 20, 2008 06:59 AM
LudemanDan
Mar 26, 2008 07:40 PM
nicoya_hyphy@yahoo.com
Sep 18, 2007 08:14 PM
whatafool
May 28, 2006 09:59 AM
