is this normal
Old Sep 14, 2007 | 11:27 AM
nicoya_hyphy@yahoo.com's Avatar
Default is this normal
I changed my tegs oil about a month and a half a go today i checked and it was empty and the oil lights was flashing is this normal for a car to burn oil this fast?
Old Sep 14, 2007 | 01:14 PM
g0tgot's Avatar
no, not at all, this happened to me when i had a bearing going out (rod bearing) my oil went like hella low, then my bearings were not lubed....then it started knocking, then i needed a new motor......better do a compression test, if the test is good then check your cooling system...
Old Sep 14, 2007 | 01:22 PM
Schister66's Avatar
Man U FTW
if you're low on oil then the light should come on, but a rod bearing isnt going to lose oil....you're going to have low oil pressure w/ bearing clearance problems. What does the dipstick register?
Old Sep 14, 2007 | 03:19 PM
Default Re: (Schister66)
zero it was emptyh
Old Sep 18, 2007 | 08:14 PM
Default Re: (nicoya_hyphy@yahoo.com)
thanks man that was very helpful.
S2KILLA
Apr 12, 2007 12:11 PM
96-EJ6 B18C
11
Mar 2, 2005 12:46 PM
dustin
Oct 23, 2002 12:06 PM
