My BIG TURBO Post. High HP D16-T Inside
Old Sep 18, 2004 | 06:49 PM
Full Race A6's Avatar
Default My BIG TURBO Post. High HP D16-T Inside
Im piecing together my turbo setup now, and I found the turbo labelled above for fairly cheap
T3/T4 with .60 Comp. A/R and .80 Turbine A/R
Seems like a ****** large turbo, but my 1.6L D is going to be completely built running a small shot of nitrous along with the boost.
Head is completely built
Milled .040
PnP
3anle valve job
Delta 272 cam
Aem adj cam gear
1mm oversize titanium valves
ferrerea retainers
dual titaunium valve springs
Block is soon to follow
Cp 9:1 Pistons
Undecided on rods, and all block work, might find a pre built one for convienience. Should I sleeve it?
Thats the snail. I honestly had a hp goal of 300whp because this car is going to be daily driven and I want a good stop light racer that wont be a slug off of the line on street tires.
Im absolutely new to boost and have only been spraying for one, year. I plan to run Turboedit
I just want some advise if I should go for this turbo and spray on it for quicker spool and major hp numbers or if I should settle for something smaller? Or is my plans concievable
Ill be running a shitbird equal length manifold, 12X 24X 3 Intercooler, HKS SSQ BOV, unkownd wastegate size
Im limited to 93 octane gas
Thanks
Old Sep 18, 2004 | 06:58 PM
D-Man's Avatar
Default Re: My BIG TURBO Post. High HP D16-T Inside (Full Race A6)
that dont look like a T3 Turbine...for a 300hp goal get rid of that turbo go with something smaller on the turbine side..like a precision SC50.
Old Sep 18, 2004 | 07:16 PM
Default Re: My BIG TURBO Post. High HP D16-T Inside (D-Man)
not a t3 turbo?
Also 300whp WAS my goal untilI found this turbo
Old Sep 18, 2004 | 07:22 PM
The Destroyer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Man &raquo;</TD></TR><TR><TD CLASS="quote">that dont look like a T3 Turbine...for a 300hp goal get rid of that turbo go with something smaller on the turbine side..like a precision SC50.</TD></TR></TABLE>
Amen, that turbine is honkin'.
D-Man's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full Race A6 &raquo;</TD></TR><TR><TD CLASS="quote">not a t3 turbo?
yeah,I'm pretty sure its not a T3...I think its a straight up T4 with a Tang/Divided Euro (Small flange) Housing...but I'm no turbo expert,lets see who else agrees
Old Sep 18, 2004 | 08:47 PM
wantboost's Avatar
Who is Mr Robot?
yep, definitely looks like a t4 turbine, way too big to be t3.
Old Sep 18, 2004 | 09:02 PM
EM1 MIKE's Avatar
Swap the turbine housing for one with a smaller a/r.
Old Sep 18, 2004 | 09:13 PM
Bloodline's Avatar
Default Re: (EM1 MIKE)
That's a T4 hot side. It gonna be a laggy bitch on that little engine. Better spray the **** out of it.
Also, you cant just swap turbine housings unless the housing are internally setup for the same turbine wheel. Like, you cant put a housing cut for a T350 on a P trim turbine wheel.
jeff
Old Sep 18, 2004 | 09:14 PM
EM1 MIKE's Avatar
Default Re: (Bloodline)
Where did I say you could just swap it for any turbine housing? I'm well aware they have to be set up for the same turbine wheel.
Old Sep 19, 2004 | 01:15 AM
f1 vtec's Avatar
definetely looks like a t4
Old Sep 19, 2004 | 02:08 AM
Bambooseven's Avatar
Default Re: (f1 vtec)
you got screwed, that is the leftovers from a T3/T4. usually you'd want a t3 exhaust housing and a t4 compressor housing, whereas yours is the opposite.
did you happen to buy that on ebay? a certain seller (ssautochrome) has been known to sell those, along with a bunch of other crap.
GL w/ that thing, I'd put money on it tha your D-series can't even spool it up. and if it does it will not be till 6500 rpm or so.
Old Sep 19, 2004 | 04:57 AM
M.A.R.C.'s Avatar
Default Re: (Bambooseven)
get a diff turbo...
that is all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bambooseven &raquo;</TD></TR><TR><TD CLASS="quote">
GL w/ that thing, I'd put money on it tha your D-series can't even spool it up. and if it does it will not be till 6500 rpm or so.</TD></TR></TABLE>
yah... GL to him... a T3 SC61 on my built Y8 (9.6:1 cr, p&p head, 2.5" dp) made full boost @ 5500rpm... imagine that big monkey
Old Sep 19, 2004 | 07:41 AM
DSF's Avatar
DSF
Im limited to 93 octane gas</TD></TR></TABLE>
Like everyone has said, that appears to be a T4 turbine housing. Which IMHO is WAY too big. Typically, on a B18B, anything over a .63 is super laggy, so I can imagine that on a D16. A lot of things you want are very contrasting...
- limited to 93 octane
- you want a stoplight racer
- you're going to use nitrous
- wondering if you should sleeve
- T4 turbine (unknown trim) with an insane a/r for a daily driven D16 rpm limit
I'd sit back and think about this a bit.
Old Sep 19, 2004 | 10:12 AM
Default Re: My BIG TURBO Post. High HP D16-T Inside (DSF)
I didnt buy the turbo, I also had suspicion about the seller so I backed out
I would have changed my setup and added xylene to my fuel to get out of the 93 octane slump, spray on it. **** sleeves
But I think Im just gonna go with what I always wanted an go high compression (12:1) with a 100-125 shot. Already have the nitrous so I only have to work about getting out all the ponies I can out of this motor
Just bought a Bisimoto header, skunk2 intake mani and looking for a 68mm t/b
Old Sep 19, 2004 | 02:03 PM
wrong, idea, go with low compression, and just get yourself a smaller turbo. like a 60/63 T3, that'd do the job just fine. hey, even spray on it if you feel so inclined.
Old Sep 20, 2004 | 07:05 AM
SOHC_MShue's Avatar
Default Re: My BIG TURBO Post. High HP D16-T Inside (NOHC)
Modified by SOHC_MShue at 3:07 PM 9/20/2004
94c1v1cex
Dec 23, 2007 01:38 PM
spgcuantik
Nov 28, 2007 08:17 AM
Bseries!EF!hatch
May 19, 2006 09:39 AM
92JDMSiR
Apr 24, 2003 08:30 PM
