Knock sensor issues with B20B-based CRVTEC?
Old Dec 9, 2001 | 11:02 PM
MrFatBooty's Avatar
Default Knock sensor issues with B20B-based CRVTEC?
OK, the B20B doesn't have a knock sensor. Running with a VTEC ECU that expects a knock sensor to be connected is going to throw a CEL, correct? Is there any way to either add a knock sensor to the B20B block or to fool the ECU into thinking that it has a correctly-funcitoning knock sensor attatched that is just sending a constant signal?
Or, does the ECU just not care about the knock sensor if one is not connected and not even throw a CEL? I doubt this would happen but wouldn't it be nice?
I forgot to ask...where exactly is the KS? From my Helms I can't even tell where it is. If it's on the head then obviously it's not an issue.
[Modified by MrFatBooty, 8:23 AM 12/10/2001]
Old Dec 10, 2001 | 12:37 AM
sgT's Avatar
sgT
Default Re: Knock sensor issues with B20B-based CRVTEC? (MrFatBooty)
There is a place for the knock sensor on a b20 block.
Just throw one in and you will be good to go.
Its in the center at the top of the block underneath the intake manifold.
Old Dec 11, 2001 | 01:10 PM
TurboLsVtec's Avatar
What I did was... get a NOC sensor from the block and tapped it to the hole that is on the head.. and it ran fine. The Sensor just needs to destec any engine detonation..
Old Dec 11, 2001 | 01:19 PM
WAFFLES's Avatar
Default Re: Knock sensor issues with B20B-based CRVTEC? (TurboLsVtec)
Or you can runa p28 ecu with a mugen program....no need for a knock sensor.
a honda knock sensor cost $104...so be careful when you install it cause it's pricey.
Old Dec 11, 2001 | 02:40 PM
GEN2 HYBRID's Avatar
What type of ECU are you running?
Old Dec 11, 2001 | 02:52 PM
mannyman's Avatar
El Veterano de Sur Califas
Default Re: Knock sensor issues with B20B-based CRVTEC? (GEN2 HYBRID)
like sgt said, there is a place for the knock sensor already on the b20's ....so there is no need to drill and tap.
manny
Old Dec 12, 2001 | 10:11 AM
Katman's Avatar
Default Re: Knock sensor issues with B20B-based CRVTEC? (sgT)
.....here's a pic of where the KS would be
SuperBowser707
Dec 4, 2012 07:49 AM
hondakrazy
Nov 14, 2008 10:42 AM
shadykit
18
Mar 14, 2005 12:51 PM
untitled
Aug 8, 2003 08:03 PM
