Brake problem
Old Sep 16, 2004 | 12:43 PM
Jaydeep's Avatar
Default Brake problem
I have 00 civic EX with 40K miles. When I hit brake my staring wheel shakes and I can hear noise. If I don't press brake paddle hard then brake works little better. This started recently before brake were sloppy. It took longer time to stop.
I don't think its my pad or rotors. I took it to mechanic and he told me it is Master cylinder.
So I don't know what is wrong. Please help me out guys.
Old Sep 16, 2004 | 12:47 PM
Jimmy's Avatar
Global Moderator
Warped rotors.. or Bad CV axle
Replace your rotors and pad's for like 50.00
If you have the knowledge to do so.
Old Sep 16, 2004 | 12:53 PM
newdad's Avatar
Default Re: (Jimmy)
Well i dont think there is anything wrong with your master cilynder but that the rotors are worped and maybe your pads are too thin i would get them checked again and please dont put aftermarket rotors if they are stock right now only use original parts they are alittle more expensive but it be better in the long run or try to see if you can get them resurfaced it be cheepe..
Old Sep 16, 2004 | 01:05 PM
Jaydeep's Avatar
Default Re: (newdad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newdad &raquo;</TD></TR><TR><TD CLASS="quote">Well i dont think there is anything wrong with your master cilynder but that the rotors are worped and maybe your pads are too thin i would get them checked again and please dont put aftermarket rotors if they are stock right now only use original parts they are alittle more expensive but it be better in the long run or try to see if you can get them resurfaced it be cheepe..</TD></TR></TABLE>
But pad are not squeaking.
Old Sep 17, 2004 | 09:52 AM
Jaydeep's Avatar
Default Re: (Jaydeep)
anyone
Old Sep 17, 2004 | 09:55 AM
jdm123's Avatar
could it be a wheel bearing?
Old Sep 17, 2004 | 10:13 AM
Jaydeep's Avatar
Default Re: (jdm123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm123 &raquo;</TD></TR><TR><TD CLASS="quote">could it be a wheel bearing?</TD></TR></TABLE>
I don't think so. My car has 40000 miles on it.
Old Sep 17, 2004 | 10:17 AM
jdm123's Avatar
depends on how hard the car has been driven for those 40k miles
Old Sep 17, 2004 | 10:21 AM
Jowee's Avatar
Change your rotors first and see what happens.
b16a2EBP
Mar 3, 2006 07:09 PM
kyden
Mar 22, 2005 07:36 PM
Mrfeee1
Oct 7, 2004 07:02 AM
blueturboteg
Dec 3, 2003 03:27 PM
acuraLSSE95
Jul 28, 2003 06:39 AM
