SC34+D16Z6=???????? anyone running one on their d-series?
Old Sep 16, 2004 | 09:26 AM
rextec's Avatar
Default SC34+D16Z6=???????? anyone running one on their d-series?
well if you are please post experiences, dyno graphs, and comments. what can i expect spool time to be on a d16z6 9.2:1 comp ratio?
thanks
btw: i have the .60/.63 57 trim
Modified by rextec at 7:30 AM 10/18/2004
Old Sep 16, 2004 | 10:59 AM
RyanEJ8's Avatar
Default Re: SC34+D16Z6=???????? anyone running one on their d-series? (rextec)
What are your power goals? I will be using an SC50 with my setup, which is a little bit smaller.
Old Sep 16, 2004 | 11:48 AM
rextec's Avatar
15/16 psi,pump gas, ahh 280whp? ireally want an even 300 but i dont know if that is attainable on pump gas.
Old Sep 16, 2004 | 12:33 PM
RyanEJ8's Avatar
Default Re: (rextec)
300whp should be easily attainable with 9.2:1 C/R on pump. I am aiming for 300whp on pump with 10:1 C/R. For only that much power you might want to look into the SC50, it would spool a little faster and is capable of somewhere around 400whp.
Old Sep 17, 2004 | 01:26 PM
rextec's Avatar
thanks for the reply! i have a new sc34 that i had for an LS but i changed my mind and im going d-series ninja! how much boost on 91 oct. do you think ill need to get to 300 whp on a built z6?
Old Sep 18, 2004 | 02:47 PM
RyanEJ8's Avatar
Not really sure. Probably somewhere around 15 psi or a little less.
Old Sep 18, 2004 | 02:58 PM
UJLSMoFo's Avatar
From: east coast performance and tuning, jacksonville, nc
Default Re: (RyanCivic2000)
i made 265whp on 14psi im also trying for 300 on pump gas. next well be 16psi on the 550 injectors.
Old Sep 18, 2004 | 04:05 PM
rextec's Avatar
Default Re: (UJLSMoFo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UJLSMoFo &raquo;</TD></TR><TR><TD CLASS="quote">i made 265whp on 14psi im also trying for 300 on pump gas. next well be 16psi on the 550 injectors.</TD></TR></TABLE>
what turbo were you running?
Old Sep 19, 2004 | 06:31 PM
rextec's Avatar
anyone else? im tryin to get 300whp at 16ish psi on 91 oct.....is this achevable? gonna be running uberdata and 550cc inj. on a built z6
hondapimp125
Jan 22, 2010 06:59 PM
LudeToAHatch
Dec 24, 2007 01:02 PM
a1320addict
Oct 15, 2005 12:46 AM
M.A.R.C.
Feb 22, 2004 09:34 AM
revhardsi
Sep 30, 2002 11:07 AM
