D16a6 with y8 headgasket
Old Sep 16, 2004 | 08:09 AM
quicksol95's Avatar
Default D16a6 with y8 headgasket
Where do i buy the y8 headgasket from? the 2 layer one?
Old Sep 16, 2004 | 08:12 AM
nighttrain33's Avatar
Default Re: D16a6 with y8 headgasket (slowsohccivic)
Just forget about the head gasket and get a DOHC swap. J/K. If you just want the head gasket go to a junkyard or the dealer.
Old Sep 16, 2004 | 08:17 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: D16a6 with y8 headgasket (nighttrain33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 &raquo;</TD></TR><TR><TD CLASS="quote">Just forget about the head gasket and get a DOHC swap. J/K. If you just want the head gasket go to a junkyard or the dealer.</TD></TR></TABLE>
Holy **** a used head gasket? WTF are you thinking dude?
I run a D16Y8 metal head gasket on my 11:1CR D16A6 in my beater and it works great.
Buy a new one from the Honda dealer and it will be under $40.00. Also torque the head to the specs for a 92-95 D16Z6 or 96-00 D16Y8 because the meatl gasket requires a bit more torque than the old fiber gasket.
I'll grab those specs for you if you need it.
Old Sep 16, 2004 | 08:22 AM
Default Re: D16a6 with y8 headgasket (B18C5-EH2)
Sorry B18! I wasn't even thinking, but thanks for the correction. Of course if he did then he could just get the DOHC.
Old Sep 16, 2004 | 08:45 AM
Spade's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowsohccivic &raquo;</TD></TR><TR><TD CLASS="quote">Where do i buy the y8 headgasket from? the 2 layer one?</TD></TR></TABLE>
2 layer cannot be bought. Basically the 2 layer is a 3 layer that someone took apart and took out the middle layer.
Stick with the fully assembled 3 layer.
Old Sep 17, 2004 | 07:47 AM
quicksol95's Avatar
Default Re: D16a6 with y8 headgasket (Spade)
well i wanna go with the 2 layer one to bump up my compression in my A6 b/c i am going to be running a delta 272 cam
does anyone have the tq specs for the y8 head?
Old Sep 17, 2004 | 08:29 AM
B18C5-EH2's Avatar
Former Moderator
Loved
The OE stock 3 layer metal gasket also raises CR slightly anyways. I'm not sure I'd trust a 2 layer, but maybe others who've done it will chime in.
Old Sep 17, 2004 | 09:13 AM
quicksol95's Avatar
maybe they will help me out
i might use the y8 in stock form and just get my spare head milled a bit
but i would really like to use the y8 2 layer and get 9.5:1 compression and just use the delta cam
Old Sep 17, 2004 | 09:15 AM
HitEm'Up's Avatar
First StepBolts 1-10) 15
Second StepBolts 1-10) 36
Third StepBolts 1-10) 49
Forth StepBolts 1&2) 49
All measured in ft. lbs.
Old Sep 17, 2004 | 09:31 AM
quicksol95's Avatar
Default Re: D16a6 with y8 headgasket (98turbohatch)
thanks
Red_ED8
Feb 23, 2008 09:13 AM
hb_guy
Oct 16, 2005 03:18 PM
SPD DMN
17
May 2, 2005 08:30 AM
civicboisi
Mar 21, 2005 01:30 PM
AgentJam
Dec 18, 2003 08:34 AM
