ITB Vacuum ports? can i run them from the stock injector holes?
Old Sep 16, 2004 | 07:26 AM
Xgen's Avatar
Default ITB Vacuum ports? can i run them from the stock injector holes?
I am building ITB's, and since i'm using he ITB fuel injector housing, i was wondering if i can use the stock manifold fuel injector housings to thread in a male connector to run to a vacuum log? any help would be great thanks.
Old Sep 16, 2004 | 08:55 AM
rice4life's Avatar
Default Re: ITB Vacuum ports? can i run them from the stock injector holes? (honda_guy_83)
here's my setup: https://honda-tech.com/zerothread?id=947796
i used jb welds because i might want to switch back to the oem injectors ports in the future, but i have seen others just tap the ports and screw the barb fittings on there.
Old Sep 16, 2004 | 07:09 PM
Xgen's Avatar
Default Re: ITB Vacuum ports? can i run them from the stock injector holes? (rice4life)
What kind of piping did you use from your flange to the ITB's?
Old Sep 16, 2004 | 11:23 PM
mEr's Avatar
mEr
very nice setup you got there...
Old Sep 17, 2004 | 03:25 AM
rice4life's Avatar
the pipes are 1 and 5/8 inch inside diameter with a 1/8" wall thickness
jdm95
Mar 27, 2010 10:07 AM
non-VTEC
Mar 13, 2010 09:55 AM
bobehud
Dec 12, 2009 11:40 AM
pinche
10
Mar 21, 2005 07:33 PM
[B16]HiGhCaM
Jun 30, 2002 08:53 PM
