windshield washer nozzles help
Hello all:
Just got a cf hood and realize that there's no pre-drilled washer holes. I did a search and I know there's people have the simliar problem but there's no follow up or update after all.
frist option, I can drill a holes but the original nozzles don't fit well coz the thickness of the location in the cf is thicker that the original hood. I am curious if there any oem style nozzles that can sercuely fit and really spray "mist" out instead of "shot" out a line of fluid?
second option, get those fan shape spray and put underneath the hood .... again... it's like a legend that no pic or write up but only being mention couple of time... I wonder if that such a thing? if so, may I know where I can get those?
my car is a 94 ex couple.
thanx
GP02A
thanx
GP02A
Thats wierd that they dont predrill holes for your windshield washer..i suggest not having the windshield nozzles and rerouting the windshield wiper pump hose and tie it to your windshield wipers. My friend did that when he got his carbon fiber hood. It just look ghetto if you tried to drill holes..you know?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecin94dx »</TD></TR><TR><TD CLASS="quote">just drill some holes</TD></TR></TABLE>It's not a big deal.
On my 79 trans am there are no hood mounted wiper fluid nozzels, they come from right under the hood above the wipers. you could make a custom bracket with some home made nozzels and run it like that. I've never seen it on a sport compact.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol93 »</TD></TR><TR><TD CLASS="quote">On my 79 trans am there are no hood mounted wiper fluid nozzels, they come from right under the hood above the wipers. you could make a custom bracket with some home made nozzels and run it like that. I've never seen it on a sport compact.</TD></TR></TABLE>I have, but only by the losers that use them for purging nitrous.
that's a waste, i've got my noz bleed of coming into my venalation system. I like getting a good buz every time I hit the little red button
hello all:
thanx for the reply. I guess it's not a big deal to drill holes. Just want to know if there any other way other than that. and I double check the space underneath the hood... and seems like it's kinda tight to put a nozzles there.
I heard that the later civic model spray mist and can swap to our eg model.... but then, the thickness of the cf hood is thicker than stock (@ the nozzles location) which won't sercuely fit there. how u guys do? just snap the original nozzles to the cf hood?
GP02A
Modified by GP02A at 10:23 AM 9/17/2004
GP02A
My CF hood came with pre-drilled nozzles, but if you do try, just make a template off the stock one. Then you're most likely going to have to shave your nozzles a bit for them to fit (I had to do this). My nozzles still don't go in perfectly, but in there tight enough so that they won't come out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GP02A »</TD></TR><TR><TD CLASS="quote">seems like most people just paint those led nozzles and put them on the cf hood....</TD></TR></TABLE>
nozzles...what nozzles? I haven't had any since the fall of 01.
my cf hood didnt come with predrilled holes, so what I did was bought some ricer led nozzles since they have a differnt base than the stock ones. it is easier to drill a round hole than try to make the stock nozzle fit with the rectangular base. I just cut the wires off and painted the nozzle black. couldnt even notice them.
yea... that's what I am looking for... the base. And I guess there's no oem like washer nozzles w/ those kind of base to attach the hood....
Will, since I live in Chicago, I definitely need them for winter.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrnicolas »</TD></TR><TR><TD CLASS="quote">my cf hood didnt come with predrilled holes, so what I did was bought some ricer led nozzles since they have a differnt base than the stock ones. it is easier to drill a round hole than try to make the stock nozzle fit with the rectangular base. I just cut the wires off and painted the nozzle black. couldnt even notice them.</TD></TR></TABLE>
I did the same thing...can't even tell now
There are places that sell that clear hose, and the plastic extenders and ****. What i've seen people do, is on that plastic molding, where the windshield wipers are...
On the corners, is this space that you can put the nozzles there. So youd have them angled at almost dead center where the driver and pasenger would look. SO this is kinda ghetto rigged, but not really. You can Drill holes in this plastic and fit it properly with washers, rubber (cut your own shapes) and make it all OEM lookin. Or b, use some strong *** 3m tape, like the **** used on the badges "CIVIC" on the back of your rear bumper. They'd be close to where the front fenders are.
dude, we're in the south. that's not ghetto at all. now hold it on with duct tape. now that's ghetto, or as I like to call it home made.
gameknb
Feb 20, 2006 02:47 PM
vabchaccord
Nov 19, 2003 09:51 AM
EGcivicBoy
11
Nov 18, 2003 05:56 PM
