Bought a VIS CF hood, and my damn squirters wont fix.
I have a VIS CF hood, and my stock windshield wiper squirters wont fix. I tried to modify it and they still wont fit in. I dont wanna drill my CF hood. Ive tried some off of an older civic and integra..
Anyone wanna help me?
Re: Bought a VIS CF hood, and my damn squirters wont fix. (EGcivicBoy)
Im gonna guess the holes too small?
I used to own a VIS hood for my old civic and I had the same problem.
You havt to drill, but don't be scared I've drilled into every hood I've owned.
Buy a drill bit thas used on glasses and plastic, they're soft.
Re: (BrynnTheSlut)
dremmel tools will work wonders on it. i had the same problem with my VIS hood and considered fixing it, then remebered i took out the window washer resivoir a long time prior.
Re: (jeremyEG)
i have a jdmshit hood and mine was the same way... that's just the way they are, i drilled mine out... it's not that hard to do, just do a little at a time and keep checking to see if they fit, go slow, and there should be no problems.
oh ya, i guess if you don't want to drill holes for your squirters, then i'm assuming you're not going to get pins
Re: Bought a VIS CF hood, and my damn squirters wont fix. (civichbb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civichbb18c »</TD></TR><TR><TD CLASS="quote">lay some tape over the area ur drilling to prevent cracking ;]</TD></TR></TABLE>
Exactly. Using a Dremel would be an easy way to widen them up
Re: (MrHeeltoe)
when i get my carbon fiber hood , i hope it doesn't come with windshield washer squirter holes, i think it looks cleaner without them.
back to the topic i would just use a file to widen the hole up a little.
