People w/ Walbro fuel pumps... did it raise your fuel pressure?
Old Sep 15, 2004 | 07:24 PM
Propulsion's Avatar
Default People w/ Walbro fuel pumps... did it raise your fuel pressure?
I want to run a b20z in a ek, people say it usually runs lean w/ an LS ecu, just wondering if by some coincidence, a new walbro pump would solve the problem... I know about fpr but if the pump add just the right amount of fuel, saves me some money.
So if you have experience w/ any of the walbro models (190/255/255hp) please let me know by how many psi's the fuel pressure increased.
Old Sep 15, 2004 | 07:37 PM
SiR831's Avatar
Default Re: People w/ Walbro fuel pumps... did it raise your fuel pressure? (SilverCIVIC96)
94 civic HB (GSR) with a stock regulator and warlboro 190 lph fuel pump. Fuel pressure at idle was 50-55 psi with the vacuum line disconnected. Dunno if this helps any...............
Old Sep 15, 2004 | 07:57 PM
Propulsion's Avatar
Default Re: People w/ Walbro fuel pumps... did it raise your fuel pressure? (SiR831)
hmm, that seems higher than stock right? Anyone know the stock fuel pressure on that car? Is it a dx/cx/vx or Si?
Modified by SilverCIVIC96 at 9:17 PM 9/15/2004
Old Sep 16, 2004 | 06:57 AM
SiR831's Avatar
i think 35 psi with the vacuum line disconnected?
Old Sep 16, 2004 | 08:40 AM
Propulsion's Avatar
Ive heard its around 40psi disconnected.. not sure though
Old Sep 16, 2004 | 08:52 AM
IN VTEC's Avatar
On my B18C1 w/ stock regulator, it consistently measures 50psi at the fuel filter with the vacuum-reference disconnected.
Old Sep 16, 2004 | 09:43 AM
Propulsion's Avatar
Default Re: People w/ Walbro fuel pumps... did it raise your fuel pressure? (IN VTEC)
this is w/ the stock pump?
Old Sep 16, 2004 | 10:37 AM
IN VTEC's Avatar
Yeah, stock pump.
Daniel-sanB1
May 28, 2006 10:31 PM
Vtec-Mike
Jan 7, 2006 10:02 AM
BoOsTiN Dc2
Feb 1, 2005 10:05 AM
E Swift
Nov 4, 2002 07:55 PM
TurboIntegra
Jul 29, 2001 11:04 PM
