B18C1 in 97 Civic Hatch
Old Sep 15, 2004 | 02:21 PM
nosturbo's Avatar
Default B18C1 in 97 Civic Hatch
My valve guide seal are leaking. So while Im getting the problem fixed I want to go ahead and put hi-performance valves, springs, retainers, etc. For this partiular engine would be better to go with high compression or low compression valves. Oversized or no? Any advice greatly appreciated!
Old Sep 15, 2004 | 02:22 PM
Spade's Avatar
Default Re: B18C1 in 97 Civic Hatch (nosturbo)
Stock size is plenty big enough. Concentrate on friction reduction.
Old Sep 15, 2004 | 02:25 PM
ABK's Avatar
ABK
first of all send off your head to the machine shop (good one). So you get the proper work done. 3angle valve job, check and replace the vavle guides if needed. What's the milage on that motor anyways.
With the vavles it's up to you (I don't know what c1 comes with stock, concave? or flat top?), boost no boost?
Old Sep 15, 2004 | 02:30 PM
nosturbo's Avatar
Default Re: B18C1 in 97 Civic Hatch (ABK)
Engine has about 65k miles on it. No boost on the engine.
Old Sep 15, 2004 | 02:48 PM
ABK's Avatar
ABK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nosturbo &raquo;</TD></TR><TR><TD CLASS="quote">Engine has about 65k miles on it. No boost on the engine.</TD></TR></TABLE>
Are you sure that's the valve seals?
Old Sep 15, 2004 | 03:06 PM
nosturbo's Avatar
Every mechanic I have talked to said thats what it sounds like the problem is. How can I tell for sure?
Old Sep 15, 2004 | 03:18 PM
ABK's Avatar
ABK
do a compression test, leak down test. See if it's not the headgasket or rings.
With 65,000 miles it's way to early to have valve seals replaced. Unless you were reving the living **** out that motor for long periods of time.
Old Sep 15, 2004 | 03:55 PM
nosturbo's Avatar
If I dont have the tools to do those tests, are there anythings to look for that might point to the rings or head gasket? On another posting I saw something about oil in the coolant meant the head gasket was bad. Is this true?
Old Sep 15, 2004 | 04:50 PM
ABK's Avatar
ABK
yep if you got oil in your coolant, or you are burning coolant it is your headgasket
did you have overheating problems yet? Just rent a compression tester from autozone if they rent it. If not it's like $20. I just can't believe that valve guide seals went that fast.
Old Sep 16, 2004 | 03:44 PM
nosturbo's Avatar
If no oil in coolant, how do I know if its the rings? How do I know what the compression tester should read?
Old Sep 16, 2004 | 05:29 PM
honda head's Avatar
dose your exhaust have a color or smell to it?
Old Sep 16, 2004 | 05:38 PM
dantastic's Avatar
i bought a compression gauge, voltmeter, timing light, and vaccum gauge tuneup set for $40. aint that expensive
Old Sep 16, 2004 | 07:03 PM
ABK's Avatar
ABK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nosturbo &raquo;</TD></TR><TR><TD CLASS="quote">If no oil in coolant, how do I know if its the rings? How do I know what the compression tester should read?</TD></TR></TABLE>
If you are getting a crappy comperssion, drop couple of drops of oil into a cylider and see if goes up. If it goes up then you got bad rings.
Old Sep 20, 2004 | 03:42 PM
nosturbo's Avatar
Default Re: (dantastic)
where did you buy the kit at?
Old Sep 20, 2004 | 03:44 PM
nosturbo's Avatar
Default Re: (honda head)
it smells like a weed eater. like a gas/oil mixture engine.
Muckman
Nov 14, 2010 11:22 AM
mrx
Dec 11, 2005 08:22 AM
USDM 4G VTEC
Oct 31, 2005 08:00 PM
ChaosUnbound
Jan 14, 2004 05:33 PM
CBR
Nov 26, 2002 08:54 AM
