VTEC Hesitation
Old Sep 15, 2004 | 11:13 AM
speedunlimited's Avatar
Default VTEC Hesitation
I'm hoping someone here can help me. Here's the problem. At times, once VTEC engages, the motor feels as if it's stumbling through the VTEC RPM range as if it's almost starving for air or fuel or it's being turned on and off. The motor is strong up until ~5500, VTEC kicks in, and stumbles all the way to 6500. Has anyone encountered this? Thanks guys.
Old Sep 15, 2004 | 11:23 AM
Pat McGroin's Avatar
Default Re: VTEC Hesitation (speedunlimited)
Is it cutting off at 6500 rpms?
I had somewhat of the same problem, with fuel cutoff at 6500 rpms, it was because of my VTEC pressure switch.
Check your codes!
Old Sep 15, 2004 | 11:29 AM
94Vtecluder's Avatar
Default Re: VTEC Hesitation (Pat McGroin)
Common problems-
1. Dirty solenoid
2. Low oil pressure
Old Sep 15, 2004 | 01:51 PM
lude298's Avatar
low oil pressure. Try not to hit vtech until you have the right amount of oil
Old Sep 15, 2004 | 02:06 PM
yOnKiNaToR's Avatar
Default Re: VTEC Hesitation (lude298)
maybe your have your dizzy timing to advanced?
Old Sep 15, 2004 | 02:14 PM
ludedude00's Avatar
yeah that happens to me from time to time, i think vtec needs a minute to warm up or whatever, i remember goin vtec about 2 minutes after i turned on my car, and the motor was cold, and vtec was skipping until i shifted, so just give it a good 10 - 15 minutes or so
Old Sep 15, 2004 | 03:55 PM
H22CL's Avatar
my car use to do that, but after i done that 2 1/2 inch collector mod it stopped that.
Old Sep 15, 2004 | 04:25 PM
01 LudeDude's Avatar
Default Re: (H22CL)
I know I've read of multiple reasons for that type of Vtec problem, but the only time that it happened to me it ended up being my a/f, it was running super rich before I tuned.
Old Sep 16, 2004 | 04:38 AM
Default Re: VTEC Hesitation (94Vtecluder)
Thanks for all yor help guys!
There's no fuel cut-off at 6500... I just stop because I think I'm causing some type of damage. I haven't engaged VTEC for a while now, but I haven't thrown a CEL code for anything yet.
Where's the solenoid located? And how is it cleaned? Thanks guys.
greg
Old Sep 16, 2004 | 08:08 AM
EOE's Avatar
EOE
Sensor Location
http://home.comcast.net/~dmitriy17/OldSensor2.jpg
New Sensor It Self
http://home.comcast.net/~dmitriy17/NewSensor.jpg
Hope that helps...
- Dmitriy
HondacivDX
Feb 19, 2012 06:52 PM
salman
Mar 14, 2005 12:43 AM
AXZ NYC
Feb 13, 2005 09:07 AM
r7
Jun 28, 2002 02:24 PM
filetofit
Mar 27, 2002 08:38 PM
