DIY Harness bar...
Old Sep 14, 2004 | 08:44 PM
TRE_'s Avatar
Default DIY Harness bar...
I"m not sure if this has been brought up before, but I searched and found nothing so here it goes.
has anyone attempted to or actually fabricated some sort of harness bar, similar to the new sparco ones? it doesnt seem like it'd be that hard to replicate, but I've never really tried anything like this.
ANY thoughts/ideas/input is appreciated.
heres a pic of the sparco unit for reference :
Old Sep 15, 2004 | 12:42 PM
TRE_'s Avatar
Default Re: DIY Harness bar... (THE_HX)
no one?
Old Sep 15, 2004 | 01:22 PM
eLUDEnu
Guest
Posts: n/a
nah I havent but If someone could make one for a forth gen prelude I would buy it
Old Sep 15, 2004 | 02:25 PM
carbonDelSol's Avatar
Default Re: DIY Harness bar... (eLUDEnu)
Im planning on doing one for my Del sol,
plan on using the seat belt mounts just like Sparco does, you're right though, doesnt look too hard to duplicate.
Old Sep 15, 2004 | 03:56 PM
TRE_'s Avatar
Default Re: DIY Harness bar... (carbonDelSol)
yea it looks like a pretty "simple" piece, but like i mentioned, i dont know too much about this kind of stuff.
you'd probably have to use DOM steel or whatever its called right?
I'm going to have a friend draw up some plans, and make a couple "prototypes" and see how that works out..
any more input?
Old Sep 15, 2004 | 06:17 PM
ewaugh's Avatar
A guy I work with is going to teach me MIG, we're probably going to weld a roll bar for mine if I can figure out how the bolt in ones bolt in, that way I can run solo I.
<FONT SIZE="1">I want a G5, but alas, only a 4</FONT>
Old Sep 16, 2004 | 01:30 AM
L-CON1's Avatar
looks pretty simple! i wouldnt use rod end to mount the up bars though. seems kinda silly to use a rod end being that it allows movement to the mounting points. not sure if thats how they are set up but by the pictures i have seen i think thats right. i would probably use a solid eye rod end. but this is just my opinion!
Old Sep 16, 2004 | 02:31 AM
Bambooseven's Avatar
Default Re: DIY Harness bar... (fab1)
I could see using the heims on a street car, you don't want to put too much stress on the B-pillar when it is un-necessary. I'd hard mount it in my car though, and just be pissed at myself down the road if I damaged the car in any way.
Old Sep 16, 2004 | 03:26 AM
89civicdx's Avatar
Its easy to do just get 2 plates and mount them on your exisiting upper seat belt mounts
then weld the bar inbetween those mounts
use DOM for the tubing
but make sure you can get harness to enter the seat at the least possible angle. then if you need to you can add those down tubes to help the bar from rotating or pulling forward.
If your making a harness bar I wouldn't use heim joints or anything that has threads, just weld everything.
But I would suggest NOT wearing a harness without roll over protection(roll bar or cage)
https://honda-tech.com/zerothread?id=978258
Old Sep 16, 2004 | 03:16 PM
TRE_'s Avatar
Default Re: DIY Harness bar... (89civicdx)
thanks for all the input everyone
Old Sep 16, 2004 | 04:24 PM
onePOINTsix's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89civicdx &raquo;</TD></TR><TR><TD CLASS="quote"> But I would suggest NOT wearing a harness without roll over protection(roll bar or cage)
</TD></TR></TABLE>if you dont have a roll cage, just use it when you go autoxing, because a road course can be just as dangerous as the street, my .02
Old Oct 8, 2004 | 08:37 AM
ALX's Avatar
ALX
Default Re: DIY Harness bar... (Sideout)
what about one for a 90-91 civic? you can use the c-pillar since the b has no belt mount, extend it forward and use the rear seats lower belt mounts for the arms.
Old Oct 10, 2004 | 01:10 AM
c jackson's Avatar
threes
Default Re: DIY Harness bar... (ALX)
hit up PSUCRX i made one for him a couple weeks ago. he might be able to snag a pic for you, although i dont know if its the same kinda thing your looking for.
Old Oct 10, 2004 | 04:47 PM
matt_sb2000's Avatar
I never thought about that.
Thanks for the link.
Old Oct 11, 2004 | 12:04 PM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
Default Re: DIY Harness bar... (c jackson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c jackson &raquo;</TD></TR><TR><TD CLASS="quote">hit up PSUCRX i made one for him a couple weeks ago. he might be able to snag a pic for you, although i dont know if its the same kinda thing your looking for.</TD></TR></TABLE>
thing is pretty sick too!
Old Oct 11, 2004 | 10:30 PM
c jackson's Avatar
threes
Default Re: DIY Harness bar... (1 point 6)
thanks man
Old May 30, 2009 | 04:31 AM
fc3srx729's Avatar
bump...
Old May 30, 2009 | 04:54 AM
95greenlude's Avatar
why?
Old May 30, 2009 | 09:53 AM
rip94delsol's Avatar
Why not?
Old May 30, 2009 | 11:04 AM
SD_Lurker's Avatar
HT White Ops
Originally Posted by rip94delsol
Why not?
Well because the thread is 5 years old....
Old May 30, 2009 | 01:19 PM
toyomatt84's Avatar
Sanji
Originally Posted by fc3srx729
bump...
boosted91crx
16
Apr 28, 2009 08:57 PM
turbo-crx
Welding / Fabrication
Feb 28, 2009 05:07 PM
thermal
21
Jun 17, 2006 08:39 PM
Power Rev Racing
10
Dec 19, 2005 06:55 PM
BrianDelSol
15
Oct 29, 2004 05:20 AM
