Crower 1.8L to 2.1L stroker kit
Old Dec 9, 2001 | 10:05 AM
mdrews187's Avatar
New User
Default Crower 1.8L to 2.1L stroker kit
I was wondering what power gains I could expect from increasing the displacment from 1.8 to 2.1 with the Crower kit. Is it reliable? Would it be compatible with turbo kits made for 1.8L engines? I would appreciate any response.
Old Dec 9, 2001 | 07:10 PM
Slick GS-R's Avatar
Default Re: Crower 1.8L to 2.1L stroker kit (mdrews187)
I am also very interested.............
Old Dec 9, 2001 | 07:31 PM
MrFatBooty's Avatar
Default Re: Crower 1.8L to 2.1L stroker kit (Slick_GS-R)
I believe it increases your stroke to 95mm. Which does NOT make for a high-rpm engine without some major block reinforcement.
Old Dec 9, 2001 | 08:03 PM
ninjaman's Avatar
New User
Very bad idea to stroke a B-series honda. It'll give you a horrible rod ratio and hose your high rev reliability.
Old Dec 9, 2001 | 08:39 PM
MrFatBooty's Avatar
Default Re: Crower 1.8L to 2.1L stroker kit (ninjaman)
That said, with a resleeved block and a crank girdle I figure you should be able to rev that stroker kit to 8000-ish RPM.
Old Dec 10, 2001 | 12:25 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: Crower 1.8L to 2.1L stroker kit (MrFatBooty)
Yep, with the 95mm crank your rod ratio goes to sh*t.
I'll agree with MFB about this one. Sleeve it, and toss in a block girdle for good measure if you don't have one.
Old Dec 11, 2001 | 11:37 AM
ninjaman's Avatar
New User
Default Re: Crower 1.8L to 2.1L stroker kit (B18C-EJ1)
Personally, if I ever go for more displacement I'd resleeve at a bigger bore and keep my rod ratio the same as stock.
egycasper16
38
Mar 21, 2019 05:17 AM
BoostnEK6206
May 21, 2007 12:00 PM
GsrIntegra789
Oct 6, 2006 01:27 PM
JDMCRX
Nov 2, 2002 03:28 PM
InfamousRS
Apr 21, 2002 11:30 AM
