going to build the bottom end of my d16z6 to handle just 10-12 psi what pistons should i get?/where
Old Sep 13, 2004 | 06:47 PM
Gant's Avatar
Default going to build the bottom end of my d16z6 to handle just 10-12 psi what pistons should i get?/where
well im planning on building the bottom end a little bit
and i would like to know what are some good low compressoin pistons/forged rods and where to get them, im planning to throw in some arp head studs, lower compression HG, some crank bearings(what do u guys recommend for that?) ive been doing research and i know i gotta up the fuel to, i finally got a nice job smogging cars at a test only and now i can finally start building the motor for some boost any help is appreciated
Old Sep 13, 2004 | 09:27 PM
b18cls1's Avatar
Default Re: going to build the bottom end of my d16z6 to handle just 10-12 psi what pistons should i get?/wh
i can get you what you need with the pistons rods hg studs ect ..pm me or call
Old Sep 13, 2004 | 09:38 PM
beerbongskickass's Avatar
I am boosting that right now on my stock d16z6. Your wasting your money building your motor up if you only going to run that much boost.
Old Sep 14, 2004 | 07:17 PM
Gant's Avatar
not really cause the motor is burning oil when i acclerate i can see it, so mite as well build the bottom end
EGdriva
25
Jan 6, 2009 09:38 PM
Black95CivicEx
Dec 30, 2008 02:11 PM
blkcoupe94
23
Jun 22, 2005 07:58 PM
litterbox
Apr 5, 2005 01:03 PM
97 BB6
Sep 9, 2003 10:49 PM
