Clicking noise...can anyone help!
Old Sep 13, 2004 | 05:46 PM
rayscar's Avatar
Default Clicking noise...can anyone help!
To any good engine Dr's out there,
For the past few months I've been hearing a clicking noise and it seems to be coming from the head of my engine. I was given info to do a valve adjustment which I did and I thought may be the problem. My car runs better, however, the noise is still there. Anyone know what else it could be?? Someone else has told me that I may have too much wear & tear in the valves b/c of 150K miles. Are they right? and would I need new valves or should I adjust the valves a little tighter, although I know the Chilton repair manual says not to go too tight. Help!! What do I have to do??
Another Q: My A/C is blowing hot air only and recently I added R134 and it started back up. The next day it was out again; when I added the R134 I noticed I was missing the lower compression valve cover, could this be my problem for the R134 to not stay in or should I just have it checked by a shop?
Any info would be greatly appreciated and as Dave Chappelle would say, "You're ganna git sum chicken!"
Old Sep 13, 2004 | 07:20 PM
pubestripe's Avatar
Default Re: Clicking noise...can anyone help! (rayscar)
with the ac, u should get that checked by a shop cuz that is wierd... otherwise can u pinpoint the sound with a stethoscope or something like it to find exaclty where it is coming from???
Old Sep 13, 2004 | 08:03 PM
jaydeemmmm's Avatar
It could very well be your valves. I have the same noise and it's because one or maybe 2 valves aren't aligned correctly or possibly bent. You should hear this noise get louder if you're going up a hill or if you're on low RPM. Some people might mistaken it as a loose exhaust pipe. I checked my pipes and it's not that.
Old Sep 13, 2004 | 09:14 PM
Two_K Si's Avatar
Default Re: (jaydeemmmm)
The ticking sound can be coming from your injectors. Honda injectors have a loud tick to them. An easy way to tell would be to take a screw driver, and with the handle to your ear, go over various sections of the motor (valve cover, injectors)
Old Sep 13, 2004 | 10:00 PM
..::91TEG-G2::..'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydeemmmm &raquo;</TD></TR><TR><TD CLASS="quote">It could very well be your valves. I have the same noise and it's because one or maybe 2 valves aren't aligned correctly or possibly bent. You should hear this noise get louder if you're going up a hill or if you're on low RPM. Some people might mistaken it as a loose exhaust pipe. I checked my pipes and it's not that.</TD></TR></TABLE>
im leaning more towards this. also check out the heat shield on the cat.. but like i said, im leaning more towards the valves
Old Sep 13, 2004 | 10:50 PM
Slain's Avatar
could be the lost motion assembly (lma's)
there is probably a slow leak in your ac lines
Old Sep 14, 2004 | 08:56 AM
rayscar's Avatar
Default Re: (Two_K Si)
I'm not sure I understand the screwdriver test, can you be more specific?
Old Sep 14, 2004 | 08:58 AM
rayscar's Avatar
Yes, it actually is getting louder. What did you end up having to do to fix it or have you fixed it?
Old Sep 14, 2004 | 09:58 AM
go250mph's Avatar
I was checking out a 92 Integ that had a B-16 swap and it did the same thing....turned out,the V-tech cyl.was getting to much current...check it out,
Old Sep 14, 2004 | 12:26 PM
Default Re: (go250mph)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by go250mph &raquo;</TD></TR><TR><TD CLASS="quote">I was checking out a 92 Integ that had a B-16 swap and it did the same thing....turned out,the V-tech cyl.was getting to much current...check it out,</TD></TR></TABLE>
i know it might of happend out of habbit but just some FYI.. before u get bashed, VTEC not VTECH
Old Sep 14, 2004 | 01:01 PM
davejj40's Avatar
Could be coming from the bottom end? If you say its getting louder it could be a spun bearing, but that maybe too extreme, but I had the same ticking sound that eventually got louder, and it was a spun rod bearing...
Old Sep 16, 2004 | 02:24 PM
rayscar's Avatar
it's actually an LS, not Vtec
Old Sep 16, 2004 | 02:27 PM
rayscar's Avatar
Actually, several people are mentioning that it could be the injectors. Others say exhaust manifold leak or bad gasket. What do you guys think? Out of all these things to check, which we be the easiest and fastest to do?
Thanks a mill everyone for all the info!
Old Sep 16, 2004 | 02:34 PM
kwoksturr's Avatar
my integra ls often has that clicking noise coming from the head as well.. but sometimes it goes away.. weird
Don JD
Sep 30, 2009 10:03 AM
Peruviann83
Mar 30, 2007 10:10 AM
jtchinoy
Jun 26, 2006 09:26 PM
redlinex
Sep 19, 2003 07:52 AM
Yuleluder
Aug 29, 2002 07:20 PM
