CLOCK IS REALLY DIM? CAN HARDLY SEE THE TIME?
Old Sep 13, 2004 | 01:50 PM
92INTEGRAGS's Avatar
Default CLOCK IS REALLY DIM? CAN HARDLY SEE THE TIME?
hi. just wanted to know if anyone else has had a problem with seeing the time on the clock in their 2nd gen teg. thanks.
Old Sep 13, 2004 | 03:39 PM
CircuitFG's Avatar
Default Re: CLOCK IS REALLY DIM? CAN HARDLY SEE THE TIME? (92INTEGRAGS)
only reason i can see it being really dim is if you are driving during the day with your headlights on. . . When you turn on your headlights the clock automatically dims. . . .The only other case i can think of is if your batter is dieing, but in that case every set of lights in your car would be dimming at the same time. . . Other than that i really don't know. . .
Old Sep 13, 2004 | 04:26 PM
CBRF4i's Avatar
Are your lights on?
If they are the car auto-dims them because fully lit it can really put a strain on your eyes
If not then i have no clue pal
Old Sep 13, 2004 | 04:39 PM
Takumi Fujiwara's Avatar
Default Re: CLOCK IS REALLY DIM? CAN HARDLY SEE THE TIME? (CBRF4i)
that clock is useless anyhow... put something useful in it like this...
Old Sep 13, 2004 | 05:19 PM
foolintherain617's Avatar
Maybe theres a connection loose, like a solder or something. Its like when you plug in headphones but not all the way so they're really quiet and fuzzy.
Old Sep 13, 2004 | 09:06 PM
Xsi's Avatar
Xsi
You can remove the dimmer wire if you drive with your lights on in the day time.
92_BlackSi
Aug 27, 2009 09:16 AM
rickashay
Apr 12, 2009 03:04 PM
hammerdgolfer
Jun 11, 2007 05:11 PM
integracura
Oct 30, 2005 10:06 AM
dip-set
Dec 30, 2002 10:06 PM
