200+ HP ?
Old Sep 13, 2004 | 12:12 PM
radeon's Avatar
Default 200+ HP ?
Is It possible to make 200+ hp on skunk 2 stg 2 cams and 82 mm bore with cr of 11.5 or so...?????
Old Sep 13, 2004 | 12:23 PM
hype r 555's Avatar
Default Re: 200+ HP ? (radeon)
i'm doing but w/ 12.5:1, you did say or so...
Old Sep 13, 2004 | 12:37 PM
na200whp's Avatar
yes ive seen it done on a stock itr bottom end.
it made 202hp and 134tq. ported head ,jdm itr header , itr intake manifold, aem CAI , skunk prog p28.
Old Sep 13, 2004 | 01:37 PM
rodrez.'s Avatar
Absolutely. HT member "MugenEG" dyno'd well over 200/135 with a JDM ITR motor, skunk stage 2's, and bolt ons. Hondata was the key.
Old Sep 13, 2004 | 01:46 PM
BigBodySmith's Avatar
I am running the Skunk2 Stage II cams, I am hoping for 200hp, check the sig!!!
Old Sep 13, 2004 | 03:38 PM
AzG35's Avatar
I made 201hp with Stage 1 cams, 81mm bore, 12:1 CR and Hondata. So yes, its possible to make 200hp+ with stage 2's and 82mm bore.
Old Sep 13, 2004 | 03:55 PM
skunt2's Avatar
Default Re: (BigBodySmith)
I'm also looking for 200+ whp.. from my setup.
Original head [b17a1] ported, polished, Frerra Valves Skunk 2 Springs and retainers. Shaved .03
Skunk2 Stage2 cams and Camgears.
Skunk2 IMF
Bigger T/B???? unknown @ this time, but will be upgraded.
DC sport header.
DC sport cat back.
Pussycatless
Original block [b17a1], bored .40 over. Decked .03
Wiseco Piston's 10.8:1
Stock rods, ballanced.
Factory crank.
Hondata s100.
I would like to do a 75 shot single fogger setup, but being that the block has been bored out to 82mm, on the factory sleves, well.. I might be pushing the reliablity of the motor.
Old Sep 13, 2004 | 07:23 PM
b19coupe's Avatar
Yes.
Old Sep 13, 2004 | 07:41 PM
JL's Avatar
JL
good luck on your build! what else besides the skunk2 stage 2 cams?
Old Sep 13, 2004 | 08:23 PM
Y2K Si FBP's Avatar
i put 197 and 130 tq stock block and stock head..just valvetrain and mugen headgasket with boltons on kenji-vafc hack. 200 whp is very possible. jdm b18c
b18Aaron
29
Apr 22, 2010 10:00 AM
B16Hatchcx
Dec 24, 2003 02:20 PM
DubyaAye
Aug 20, 2003 04:45 PM
s2k420
Oct 12, 2002 06:40 AM
