kinda stupid question....
Old Sep 13, 2004 | 10:53 AM
lga860's Avatar
Default kinda stupid question....
is there an easy way in taking off the gasket from the intake side of the head? Its stuck on there really good....
Old Sep 13, 2004 | 10:55 AM
Train's Avatar
Default Re: kinda stupid question.... (lga860)
huh? the headgasket? its one piece. or do you mean the intake manifold gasket?
please explain a bit better.
G-bonic's Avatar
Hijacked
WD40 or engine degreaser soak ot for a while and then scrape it off....
Old Sep 13, 2004 | 12:32 PM
djbutler007's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lga860 &raquo;</TD></TR><TR><TD CLASS="quote">is there an easy way in taking off the gasket from the intake side of the head? Its stuck on there really good.... </TD></TR></TABLE>
flathead screw driver
Old Sep 13, 2004 | 04:17 PM
lga860's Avatar
Default Re: kinda stupid question.... (Train)
yea the intake manifold gasket... its stuck on there really good... tried all those.. soaking it with engine degreaser, wd40... i guess i have to use more..
Old Sep 13, 2004 | 04:27 PM
SicNA94TegGsR's Avatar
Swollen Member
I have a set of wide scrapers at work from Cornwell, designed for that, so I am guessing that a putty knife would work as well, it gives you a wider surface, to spread out the "force" so one, you dont gouge the metal as easily, and two, you can really get under there, and pry alot at once
Old Sep 13, 2004 | 05:57 PM
LSvtec03's Avatar
Default Re: kinda stupid question.... (SicNA94TegGsR)
there's a gasket remover spray that works pretty well. just let it soak in for a few minutes and it scrapes off really easy. you can prolly get it at any auto store.
Old Sep 13, 2004 | 07:18 PM
pubestripe's Avatar
Default Re: kinda stupid question.... (LSvtec03)
i actually found that by using simple green, diluted with a window scraper got mine off really easily when i replace my manifold...
Colombiano127
12
Jan 3, 2008 02:34 PM
MassCivicMan987
Jul 1, 2006 05:22 AM
MR. MIYAGI
Mar 26, 2004 08:01 PM
Boostage
Feb 7, 2004 08:42 PM
boot machine 5000
Jun 17, 2002 08:26 AM
