Synthetic oil?
Old Sep 12, 2004 | 04:31 PM
RemerLex11's Avatar
Default Synthetic oil?
ive heard plenty of diff things but is it gonna hurt ur engine if u use synthetic oil after using non-synthetic?
Old Sep 12, 2004 | 04:58 PM
Mario.'s Avatar
Default Re: Synthetic oil? (mafoo_2005)
Yes it will kill it.
Old Sep 12, 2004 | 05:16 PM
SuperSlow's Avatar
https://honda-tech.com/zerothread?id=979961
USE IT. The link, I mean.
Old Sep 12, 2004 | 08:02 PM
Luchini's Avatar
Default Re: Synthetic oil? (Mario BA4)
I think going from non syn to syn oil is ok but vice versa is not.
Old Sep 13, 2004 | 06:43 AM
SuperSlow's Avatar
Default Re: Synthetic oil? (Luchini)
Don't think. You are wrong.
Old Sep 13, 2004 | 06:48 AM
Kal's Avatar
Kal
Only if your car is high mileage. Synthetic oils flow better and might make compression drop because of the built up stuff found in higher mileage cars.
Old Sep 13, 2004 | 07:30 AM
Sephro's Avatar
Default Re: Synthetic oil? (Kal)
You can swap. I did at 180k miles. Yes I burn a little oil now (1qt every 3k miles) The only thing you want to make sure of is that you do not use a detergent syth oil. You might start to get some leaks from worn seals because the syth oil has smaller particles but I wouldn't be too worried about it. You can swap back if you decide you don't like it... If you couldn't why would they sell stuff that is half syth half dino?
Old Sep 13, 2004 | 08:10 AM
kellyk75's Avatar
Default Re: Synthetic oil? (Sephro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mario BA4 &raquo;</TD></TR><TR><TD CLASS="quote">Yes it will kill it. </TD></TR></TABLE>
WHAT?????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow &raquo;</TD></TR><TR><TD CLASS="quote">Don't think. You are wrong.</TD></TR></TABLE>
Sorry, but you guys need to know what you are talking about before you post.
How many cars do you think come with synthetic when you buy it. IT IS FINE to go from dino to synthetic, but not good to go from synthetic to dino. There are some steps you can take to do it but it is best not to. The synthetics have detergents that coat the engine and will repel regular oil....... but it depends who you talk to. There are a lot of opinions out there on this, but ALL the experts agree that it is safe to switch to synthetic.
Check this out
http://www.preludeonline.com/s...hetic
Old Sep 13, 2004 | 10:26 AM
ItalynStylion's Avatar
My 5th gen has 59k on it, is that considered "higher milege"
Would switching to synthetic be benificial or bad?
Old Sep 13, 2004 | 02:49 PM
Wiseguy619's Avatar
When I first bought my lude, I did an engine flush than switched to synthetic. Currently using Mobil 1 and I am very satisfied. Is anybody running Royal Purple? I was considering it for my next change.
Old Sep 13, 2004 | 04:31 PM
SuperSlow's Avatar
Default Re: Synthetic oil? (kellyk75)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kellyk75 &raquo;</TD></TR><TR><TD CLASS="quote">
I swap back and forth depending on how much time I know I will have to change. In the summer when I am driving hard more often and have more time to do frequent changes I use cheaper dino, and in the winter when I don't enjoy freezing off my nuts to change the oil, I stay out of VTEC and use fully synthetic. Never had a prob, running 174k miles strong...
Maybe I don't know what I am talking about, but I do know what I am doing. So.... STFU.
Oh yeah, ur canadian, i should be nice.
Old Sep 13, 2004 | 08:29 PM
equinox's Avatar
Default Re: Synthetic oil? (ItalynStylion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ItalynStylion &raquo;</TD></TR><TR><TD CLASS="quote">My 5th gen has 59k on it, is that considered "higher milege"
Would switching to synthetic be benificial or bad?</TD></TR></TABLE>
higher mileage = 75k+ miles
Old Sep 14, 2004 | 06:25 AM
Sephro's Avatar
Default Re: Synthetic oil? (lude_roller)
I swapped at about 180k miles. Leaks a little more than it used to.. but not much more. I think it's better than the dino IMO.
Old Sep 14, 2004 | 06:53 AM
kellyk75's Avatar
Oh yeah, ur canadian, i should be nice.</TD></TR></TABLE>
lol...... If you re-read my post you will see that I agree with you. It is the people who say it will kill your engine if you switch that I think need to do some research. Everyone should read the link I posted..... it is a bit of a read but has tons of information.
How long have you been switching back and forth?
Old Sep 14, 2004 | 09:55 AM
vinuneuro's Avatar
Chill out. He was being sarcastic.
Old Sep 14, 2004 | 09:59 AM
gsr-2nr's Avatar
Default Re: Synthetic oil? (vinuneuro)
oil is oil it wont hurt it
Old Sep 14, 2004 | 10:14 AM
devi1man's Avatar
WHAT?????
Check this out
http://www.preludeonline.com/s...hetic</TD></TR></TABLE>
Where did you get that from??? Detergents to repel regular oil????
ALL and I do mean ALL multiweight oils are partially synthetic. The only problem in the detergents in Synthetics is that they break down the sludge left by conventional oils and may lead to leaks. On an engine with less than 75k, you can switch either way.
Old Sep 15, 2004 | 10:11 AM
98lude-t's Avatar
i use it in my car it runs smoother stays cooler and doesnt burn any more or less than it did before. and i always check that crap.
15psi and h2o injection on 108,000 STOCK motor. no probs yet
ran it for 8k now.
dnoonkeste
Honda Civic (2001 - 2005)
Jun 28, 2011 10:47 PM
EG-SIXV-TEC
27
May 3, 2010 09:27 AM
azzure180
Sep 8, 2009 09:18 AM
99 HXagon
21
Jul 26, 2002 06:28 AM
TypeR01-424
Aug 17, 2001 07:51 AM
