Apexi VAFC
i just installed my apexi vafc...whenever i floor it...my car bogs and kicks back at 6500. is there a way where i can change that on the controller? i cant seem to find a way. i need it to let me rev up to redline at least.
would it be a wiring problem or just need to do it through the controller?
[Modified by Drew408, 9:43 PM 12/8/2001]
If you initialized it proper, then it should have no affect on the way the engine runs -if- you leave everything at stock settings. You probably just have a loose wire or something. Also there are wires that need to be spliced in a different distances from the ecu, make sure the correct wire is closer.
Yup...your car should run like stock until you start playing with it.
i think i know whats wrong...i think everything is ok...its just that my check engine light is on and i have to go get it reset....if the engine light is on...the rev limiter comes in earlier...correct? thats my problem.
chrisir19
Sep 23, 2003 08:42 AM
