Any one know why my car stumbles at WOT while in boost? HELP!
My car is hesitating at WOT while entering boost at about 4500rpm. when i increase the throttle slowly and i don't go straight to WOT it doesn't stumble as bad. its really noticeable in 2nd gear. i have an autometer air fuel gauge and it seems to be running lean at WOT but when in boost and at partial throttle it doesn't seem to run lean. when i'm in 4th or 5th on the highway it doesn't seem to misfire/stumble/hesitate. what could it be? could it be the clutch? i have an exedy stage 1 thats about 2 months old. stock flywheel. will a b+m fuel pressure regulator and gauge help my problem? does increasing the fuel pressure matter if i still have stock injector and no real fuel management.
Here's my setup:
B18B (stock)
ngk iridiums gapped at .03
nology wires
msd sci
stock injectors
12:1 FMU
inline fuel pump
HELP!
THANKS IN ADVANCE.
Here's my setup:
B18B (stock)
nology wires
msd sci
stock injectors
12:1 FMU
inline fuel pump
HELP!
THANKS IN ADVANCE.
Well I know for sure that those platinum / iridium plugs are to be stayed away from with FI. You are better off running some cheapo-copper $.89 cent each plugs and changing them every other oil change or so.
That's probably a big part of your problem right there.
Matt
Matt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brixity »</TD></TR><TR><TD CLASS="quote">what copper joints do would u recommend? any?</TD></TR></TABLE>
NGK ZFR7F-11's gapped to .030
vtec_killer_
Feb 17, 2008 10:06 AM
B_1_8_hatch
Nov 1, 2003 08:36 AM
RATEDR
Jul 9, 2002 12:26 PM
