does anybody have write up on how to do an oil change?
does anybody have a write up on how to do an oil change or something like that?
my dad is in the navy so he is never around to teach anything like that and no use asking my mom.
thanks.
thanks.
Drain the oil from the pan, uninstall the filter, fill new filter half way with oil, put oil on the o-ring, reinstall filter, reinstall oil pan bolt and pour oil in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ralpheyizzle »</TD></TR><TR><TD CLASS="quote">does anybody have a write up on how to do an oil change or something like that?
thanks.</TD></TR></TABLE>
and this is going on my list of reasons why i will be getting out
you want some oil in the oil filter so that when you start up the car there can be some oil through that area if the angle of the filter is extreme.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Twiggz »</TD></TR><TR><TD CLASS="quote">don't forget jack stands! </TD></TR></TABLE>
I agree, safety first, your life is on the line.
I thought the filter was "primed" so the pump doesn't take so long to pressurize the system. When you first start the engine after an oil change there is no oil pressure, so your "Oil" light will be on. It should/better go out after 5 seconds or so. Longer then that means there's probably not enough oil in the pan.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kb58 »</TD></TR><TR><TD CLASS="quote">I thought the filter was "primed" so the pump doesn't take so long to pressurize the system. When you first start the engine after an oil change there is no oil pressure, so your "Oil" light will be on. It should/better go out after 5 seconds or so. Longer then that means there's probably not enough oil in the pan.</TD></TR></TABLE>
I have never gotten an oil light when I've changed my oil... not even for a second.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mario BA4 »</TD></TR><TR><TD CLASS="quote">Drain the oil from the pan, uninstall the filter, fill new filter half way with oil, put oil on the o-ring, reinstall filter, reinstall oil pan bolt and pour oil in. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j boy »</TD></TR><TR><TD CLASS="quote">http://www.c-speedracing.com/h...l.php</TD></TR></TABLE>
thanks for the help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kb58 »</TD></TR><TR><TD CLASS="quote">Also consider taking an autoshop class.</TD></TR></TABLE>
i wish my school offered an auto shop class yo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shakes »</TD></TR><TR><TD CLASS="quote">
and this is going on my list of reasons why i will be getting out </TD></TR></TABLE>
yah its a good idea. you dont want to be away from your kids for 20 years.
I have never gotten an oil light when I've changed my oil... not even for a second.</TD></TR></TABLE>
Also, Do not overtighten filter or the drain bolt when you put it on....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow »</TD></TR><TR><TD CLASS="quote">
How much is too tight cuz im about to change my own oil soon. Also about how much oil do I need to buy? and this question must be real retarded but im gonna ask to make sure. On the oil dip stick there are two dots, so im suppose to fill it up til its between those two dots?
I tighten my filter hand tight, then give it another 1/4 turn.
There is a quart of oil difference between the two dots. Fill it so that when cold and the car is level, the oil comes up to the 2nd dot.
hand tighten the filter as much as possible. torque down the drain bolt though. I think it's 45NM if you have a torque wrench.
You'll probably need between 4-5 quarts and you want to fill it up to the top dot. I know SI is 4.5Q
h22 is 5 quarts. if you dont want to risk screwing with your car, why dont you take it to get an oil change? although they are easy to do, it might be better in your case to just spend the $15 dollars to have them change everything.
they change oil and filter AND windex your windows and mirrors for you... if you find the right place sometimes they will throw in a free car wash too!
happynoodleboy
Feb 20, 2008 06:34 PM
lowgman
Apr 21, 2004 04:14 PM
Floyd
Sep 23, 2003 07:08 AM
dclub01
May 1, 2003 03:22 PM
