what's the difference between a big shaft garrett 60-1 and T61?
Old Sep 10, 2004 | 05:53 PM
BuBBa y0!'s Avatar
Default what's the difference between a big shaft garrett 60-1 and T61?
i'm still learning about turbo's and what not, so i was wondering if anybody could fill me in about them!
thanks in advance
Old Sep 11, 2004 | 03:40 AM
BuBBa y0!'s Avatar
Default Re: what's the difference between a big shaft garrett 60-1 and T61? (Bubba55)
nobody knows?
Old Sep 11, 2004 | 05:38 AM
b18cls1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bubba55 &raquo;</TD></TR><TR><TD CLASS="quote">i'm still learning about turbo's and what not, so i was wondering if anybody could fill me in about them!
thanks in advance</TD></TR></TABLE>
big shaft 60-1 has a inducer of 2.524 and a major of 3.00
t61 has a inducer of 2.4 and a major of 3.540
about a 1/2 inch of major wheel diamter
the 60-1 will run out of its peak effiency at 1 bar of boost at 45lbs of air
where as the t61 will be at 2 bar of boost at 55lbs of air
not saying that either one wont make more boost that is just the limit of the peak effeincy
Old Sep 11, 2004 | 12:35 PM
BuBBa y0!'s Avatar
Default Re: what's the difference between a big shaft garrett 60-1 and T61? (b18cls1)
thanks for the info! but is that it? will one turbo boost earlier/harder than the other?
Old Sep 11, 2004 | 04:07 PM
b18cls1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bubba55 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the info! but is that it? will one turbo boost earlier/harder than the other?</TD></TR></TABLE>
the t61 will flow more air so it will ahve more hp potential and as far as spool goes that really depends on what turbine housing you are using
Old Sep 11, 2004 | 04:31 PM
rondigs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cls1 &raquo;</TD></TR><TR><TD CLASS="quote">
Are you sure about that????!!
On race gas (the top numbers) was well beyond 1.0 bar. And BTW, this is from the little guy 60-1 hifi.
Old Sep 11, 2004 | 04:38 PM
Boostfed's Avatar
New User
Beat me to the punch!
Old Sep 12, 2004 | 10:20 AM
b18cls1's Avatar
Default Re: what's the difference between a big shaft garrett 60-1 and T61? (rondigs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rondigs &raquo;</TD></TR><TR><TD CLASS="quote">
On race gas (the top numbers) was well beyond 1.0 bar. And BTW, this is from the little guy 60-1 hifi. </TD></TR></TABLE>
yes i am im not saying that the 60-1 wont make more than 1 bar but will be out of its peak eff ring on it map *** seen below on its map see the middle ring, thats its peak eff. noew look at the pr ratio and 2.0 is 1 bar at the top of the center ring, so yes i am sure
Old Sep 12, 2004 | 09:25 PM
BuBBa y0!'s Avatar
Thanks guys for all the responses, it's help out a lot! To make it more confusing, is ther a big difference between a small and big shaft turbo? And as far as the T61, are there ones better than the other? Due to so many companies making a variation of that turbo such as Precision, Garrett, Innovative, and etc... Again, I can't really ask if which one is the "best" because it all depends on my setup. But why would one company be preferred over the other?
Old Sep 13, 2004 | 08:53 AM
DIRep972's Avatar
Smarter than you
Also, keep in mind the 60-1 uses 7 blades on the compressor wheel where the t61 uses only 6.
Old Sep 13, 2004 | 09:19 AM
twkdCD595's Avatar
wow I never realized the 60-1 was out of peak so quickly.
Old Sep 13, 2004 | 09:26 AM
BuBBa y0!'s Avatar
Default Re: what's the difference between a big shaft garrett 60-1 and T61? (twkdCD595)
bump for a knowledge fest
Old Sep 13, 2004 | 01:01 PM
b18cls1's Avatar
Default Re: what's the difference between a big shaft garrett 60-1 and T61? (DIRep972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">
Also, keep in mind the 60-1 uses 7 blades on the compressor wheel where the t61 uses only 6. </TD></TR></TABLE>
yes i forgot to add that
thanks
Old Sep 13, 2004 | 02:35 PM
1.8T_EG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 &raquo;</TD></TR><TR><TD CLASS="quote">wow I never realized the 60-1 was out of peak so quickly.</TD></TR></TABLE>
from the archives, i started a discussion about the 60-1. most agreed that the turbonetics map is not the true 60-1 map.
https://honda-tech.com/zerothread?id=524495
https://honda-tech.com/zerothread?id=539308
ying_YANGtwin
Dec 16, 2004 05:55 PM
Sam1am26
Nov 26, 2004 06:51 PM
Mr.DC2TurBo
Mar 26, 2004 10:32 PM
CiViC SiR
Oct 10, 2003 11:49 PM
SimonsTeg
Sep 13, 2002 01:38 AM
