HELP pls have I KILLED the Clutch?? its 94-01 JDM Integra orig B18C
Old Sep 10, 2004 | 11:25 AM
wallstreet's Avatar
Default HELP pls have I KILLED the Clutch?? its 94-01 JDM Integra orig B18C
I am UK based but its similar to the GS-R in most ways...
I raced around the backroads and have hardly really kicked hard on the car... I found the clutch making a strange noise getting into 1st gear from starting but then went smoothly along the gears...again stoppped and started and same problem... heard odd clutch noises when not even trying to put 1st in (thats only noisey when it is pressed in FULLY), but pushing the clutch down..... went out started the car, no problem, pushed down a few times and it erupted and then went away....
Fluid levels are perfect in the small container that says dot 3 or 4 which is for the clutch ... it is a hydraulic one... AM I STEWED is this going to COST me the moon?
What have I done to her.....
I think this is what it is?:-
Step 2 If that is not the problem, place your foot on the clutch pedal and begin to depress the pedal. If you begin to hear the noise at this point, the problem is the clutch release bearing. If not, proceed to the next step.
Old Sep 10, 2004 | 11:38 AM
hott-nix's Avatar
Default Re: HELP pls have I KILLED the Clutch?? its 94-01 JDM Integra orig B18C (wallstreet)
i would take it to a shop and have them check it out.
perhaps maybe take it directly to a honda dealership and have a honda mechanic drive it. if anyone knows, it would be him
Old Sep 10, 2004 | 12:15 PM
wallstreet's Avatar
Default Re: HELP pls have I KILLED the Clutch?? its 94-01 JDM Integra orig B18C (hott-nix)
I shall....Honda locally are not very good as they dont sell these Imports....but I know a specialist who only deals with these who can have a go at it....
Cheers
N
Old Sep 10, 2004 | 08:58 PM
wallstreet's Avatar
hiya
today I am going to get the Teg looked out.....to ssee what/how much it will cost to get the clutch fixed..I think its the thrust bearing or else..... clutch worn out which can be fixed easy......
N
Old Sep 10, 2004 | 10:22 PM
eK9aT10pSi's Avatar
before the problem occured, did the clutch feel soft? if it does, imo, replace the clutch while ur at it becuase since you have to pull the tranny off. and check the flywheel too. ususally if u buy a clutch kit, it comes with the plate, disc, poliot bearing and throwout bearing.
ender214
Aug 19, 2008 12:54 AM
TigerLy
Jul 16, 2008 01:59 PM
Flexer
Apr 16, 2004 07:43 AM
TylerC
Jan 13, 2004 01:25 PM
